Question about Humminbird FISHFINDER 597CI COMBINATION ()
In water deeper than 400-500ft works erratically showing depths of 0 -20 60 -114 etc. is there something i need to set for deeper water
  • 29 Answers
Try going into the menu and restoing the defaults just to make sure that are not any incorrect settings. This will restore the setting bact to the factory settings. If this does not correct your problem you can contact out customer service group and they should be able to trouble shoot your problem. Our number is 800-633-1468.
Joby from Humminbird
Posted on Jan 03, 2011
Ray Marine ST 40 Bi Data System Depth not working out of water.
it will not work out of the water my friend. . .really?????
Dec 29, 2012 | Boating
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
I am trying to replace my old slide in gas range (Magic Chef- model # 6498XTS with a new slide in gas range and am trying to find out if the new one will fit where the old stove was, here's my problem the...
The installation depths provided in the installation literature, are the minimum requirements for fitting the slide in range into place. You need to determine what the depth of your opening is where you intend to install the appliance. The depth shown on the installation instructions might be showing the overall depth of the appliance, including the oven door, which typically sticks out from the cabinet anywhere from 1-3 inches, depending on the brand, model, etc. The old Magic Chef might have only provided the needed depth for the oven body, and might not have included the front oven door projection, past the countertop, etc. Most cabinents are about 24 inches deep, so anything larger than that, will likely stick out into the room more, unless your cabinents are deeper than 24", you're looking at having the new slide in oven stick out past the front cabinet front/edge, by about 4 5/16". I'd make a cardboard template to the dimensions of the new oven and use that to see just what you're facing with the replacement oven. It could be possible that you've confused the depth with the width for the new oven, as I've not seen many ovens that are as large as 28" unless it was a Viking, or other really high end, professional style oven, etc. Check your installation dimensions again for the Maytag and make a cardboard template to confirm how much space will be needed. The good news is that you can remove the old Magic Chef, since it's not working, to allow you to make a more informed decision as to fit and clearances required for the new oven. Just be sure to disconnect the power to the range or unplug the power cord, if that's what it has, before attempting to remove the slide in. Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Eagle Cuda 168 has no display over 30 feet of water
Try good alakaline batterys(duracell or energizer)alot of those rechargables dont hold amperage and dont stay recharged long!!!! :)
Jul 05, 2009 | Eagle Cuda 242 Portable Fishfinder
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Erratic depth and does not indiacte any fish
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to sensitivity set to manual then go up one on the menu and set it to 95 – 97 this will clear up the rapid change now set zoom to manual. Your back and running.
Mar 31, 2009 | Eagle Cuda 242 Portable Fishfinder
4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
Nov 05, 2008 | Navman Fish 4150sx GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Humminbird FISHFINDER 597CI COMBINATION () Logo
95 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
