Question about Ingersoll Rand TS4N5 Ir Electric Stationary Air Compressor 5HP. 80 Gallon Vertical Two Stage
What size breaker do i need for the ingersoll-rand ts4n5 air compressor
  • compman66
    compman66 Jan 02, 2011
    on what voltage? and single phase or three phase?
5 Suggested Answers
agent91
  • 2100 Answers
SOURCE: wire size
I used to know all this stuff, the hardware store has a gauge guide to show you the correct size, i would guess that 8 would be ok, 10 would probably do it, hope this is right.
Posted on Apr 12, 2010
  • 205 Answers
SOURCE: i have a new ingersol
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Posted on Jan 16, 2011
  • 205 Answers
SOURCE: what weight of lubrication do i use for this
Yes it is always a good practice to bleed the tank down. there is a check valve in the top of the receiver tank that keeps air from blowing back Thur the system. However if it's leaking you will have pressure on the oil sump. As for type of oil use a 30 weight non detergent oil. Recommend using ir's t30 all season or another type made for air compressor's.
Posted on May 28, 2011
  • 205 Answers
SOURCE: What size breaker do I
Look at the motor tag. It should give you the run amps which I believe is about 22. What ever your amps are on the tag multiply by 1.5. If it comes up like my example (11 + 22 = 33) go to the next available size. Like 35 or 40. This should size the breaker to get the unit through start up.
Posted on Aug 08, 2011
What size breaker do I need for a Ingersoll Rand Model TS4N5
Aug 07, 2011 | Ingersoll Rand TS4N5 Ir Electric...
What weight of lubrication do i use for this compressor...Ingersoll Rand TS4N5? And do I need to bleed the tank off before adding oil?
May 23, 2011 | Ingersoll Rand TS4N5 Ir Electric...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
Can't get it to come on when it's cold.
Warm it up with a heat lamp, hair dryer etc. Release all air pressure from the tank first. Check your oil and use only compressor oil.
Dec 22, 2010 | Ingersoll Rand TS4N5 Ir Electric...
I have a ingersoll rand 30, srats for 20seconds then trips breaker,,,runs great when running
Sounds like the unit is pulling to many amps during start up. Possibilities are: breaker under sized, wire under sized, to long of a run of wire from breaker for wire size,Tank check valve bad. I would check the amps during start up and while running and compare to motor name plate information. Remember at start up the motor may pull 1.5 to 2 times the rated amps on the name plate. Also if this unit has a magnetic starter wire connections may be loose or overloads to small.
Dec 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Which direction should my compressor motor be turning when looking at it from the shaft or pulley side side?
Easy to tell which direction motor should turn. Look at the flywheel of the pump it will have an arrow showing direction. Secondly,the pump has fins that need to turn in direction to blow air onto pump. Good luck
Sep 22, 2010 | Ingersoll Rand TS4N5 Ir Electric...
Wire size
Apr 12, 2010 | Ingersoll Rand Air Compressor Maintenance...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Ingersoll Rand  TS4N5 Ir Electric Stationary Air Compressor 5HP. 80 Gallon Vertical Two Stage  Logo
336 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
