Question about Freestyle Betty Shark X Mid Watch - Black - 77601 Watch for Women
Hi I can't pull out the crown..any suggestions. Misplaced manual is there a trick to pulling out the crown...really hard to pull it out.
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
How do I set the time on a Mulco MW2-28050S-021?
I can't find a manual for this watch, but did you try to rotate the crown counter clock wise and if that works, when lose, pull to adjust the time.
Jan 08, 2015 | Watches
Invicta corduba #4898. Crown will not pull out to adjust time and date. Large cap removed, smaller croen head will not come out. Is there a trick to it? Thanks, Steven
Divers watches usually have to have extra strong seals to prevent water getting in. This often achieved by screwing the crown wheel (to the right?) after it has been pushed home.
To pull the crown out, first rotate it anticlockwise about 1/4 of a turn and then pull.
Jun 16, 2011 | Invicta Corduba Ibiza Diver 4898 Watch for...
Is there an easy way to change the date on my breitling crosswinds watch without manually rolling the crown through 24 hours every day?
Of course, there is the way to do that. Try to pull out crown carefully and you will notice that there are two positions (clicks). Second click is when the crown is fully pulled out and the watch hands move by turning crown. But there is first click (lets say - crown is pulled just half way out). In this position the date/day can be quickly changed by turning the crown. Crown=winder.
Feb 27, 2011 | Bulova Watch
Date will not chage!
Click on my profile (escapement), then click on Tips and Tricks. There you will finds link to all watch manuals. Rate me, please..
Mar 29, 2010 | Diesel DZ1090 Watch
Seiko 7t62 Coutura Black Ion; alarm resets NOT to current time but to about 3 hours later?! Yes, I have RTFM ;-)
Click on my profile, then click on TIPS AND TRICKS. There you will find link for all Seiko watch manuals. Download yours and learn how to reset the alarm. Rate me, plz.
Feb 20, 2010 | Seiko Coutura Chronograph Watch
I cant pull out the date/time pin on my luminox 3204. any suggestions?
On some watches - scuba usually - the crown has a rubber seal and that seal is engaged when the crown is screwed to the case. If your watch is like this, you need to unscrew the crown before you can pull out the stem. Twist the crown in a counterclockwise direction several turns. You will be able to tell when it is completely unscrewed because youwill feel spring tension. Pull out the stem to set the watch. When you finish, push the stem back in. Push against the spring tension and carefully thread the crown back onto the case. That should do it.
Jun 12, 2009 | Luminox Navy Seal Dive 3204 Wrist Watch
Setting time and date on my Cartier Pasha watch.
Do not be so afraid. Unscrew that big crown fully, pull off and then you will see the real setting crown(quite small one), called an underlayed crown.
That little chain is hard enough to withstand your pulls, unless you are drunk. :)))
When you get that small crown handy- you can set the time and all the features.
If the small crown is not moving, your watch is rusty and you will need a proper watchmakers help.
Don't forget to rate, please.
Jan 11, 2009 | Cartier Pasha 32MM WJ111156 Wrist Watch
Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
May 02, 2008 | Rolex Daytona 116520 Wrist Watch
Freestyle Betty Shark X Mid Watch - Black - 77601 Watch for Women Logo
43 people viewed this question
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
