Question about Yamaha HTR-5550 Receiver
The receiver, tv and cable are all on but there is no sound. the cable company has checked everything on their end and say the problem is not with the cable. Our sound is run through the receiver. I use 2 different remotes. one is the cable remote that operates everything but the sound. the receiver remote is used only for the sound. can you help me please?
    Genius:
  • 1,126 Answers
Unplug the TV and the receiver from the wall for 40MIN, if you have your TV hooked to it, they, will reset the processor back to normal and clear them out, and everything should work OK.
Posted on Jan 02, 2011
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
No sound with cable tv- AM/FM works ok
First, check all the connections to the receiver.. Make sure everything is plugged in where it should be.. Also make sure, that when you are on TV/CABLE that the surround sound is selected and that "headphones" is not.. Also check any other modes that may have been changed, (IE digital input, 5.1 channel, etc...)
Apr 05, 2008 | Yamaha RX-V661 Receiver
I have Dish Sattelite. The screen on my JVC digital tv says digital strength is low. Do I call Dish? or ?
This sounds like a cable issue. Assuming your Dish receiver is connected to your TV with a HDMI cable (ends are rectangular and the connector is trapezoid in shape), you can first attempt to switch HDMI ports on the back of your TV. If you get the same message, you can try flip the cable end for end -- plug the TV end into the receiver and the receiver end into the TV (I know, sounds silly, but has worked for me). Next is a new (better -- don't get a $5 cable, most good HDMI cables start close to $20 and up depending on length).
Now if you happen to be connecting via a "standard" TV cable (RG 6), first make sure that the cable is screwed on snuggly (no wrench needed, just finger tight). Next is to get a new cable.
May 01, 2014 | JVC AV-20020 20" TV
My blu ray and regular DVD player have sound coming through the tv, but the tv itself on a regular chanel like ESPN, there is no sound. This is a Mitsubishi 73" DLP.
You have completed the proper troubleshooting, and by process of elimination you have determined that there is nothing wrong with your television's sound. The problem lies in cable. The next troubleshooting steps depend upon how you receive your cable channels. If you have a cable box (or a satellite receiver) you may just need to unplug it for 30 seconds to reboot it (or follow the instructions from a cable/satellite company representative on how to properly reboot your particular cable box/satellite receiver model). Also commonly the cable box/satellite receiver is not set to output audio properly. If you are connecting it to the television with an hdmi cable the audio output must be set to hdmi. Also there may be a setting pcm or bitstream. The cable box audio setting normally would have to be changed to pcm.The problem may be with the cable box/satellite receiver itself needing to be replaced or the cable cord connecting it to the television may need to be replaced. It is less likely that the television has a setting the one source input the cable box/satellite receiver is connected to that would affect the sound but confirm that there is or isn't. Last there may be something wrong with the source input you have the cable box/satellite tv receiver connected to.
If you do not have a cable box/satellite tv receiver then rescan your channels, try a different cable cord, and check with the cable company to make sure there is no internal issue at the moment.
May 11, 2011 | Televison & Video
Which end is the receiving end of a house tv areial
peter_321
One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
Ray Calo
DISH Network
Mar 05, 2011 | Televison & Video
Connection for cable
A snowy picture is usually an indication of a bad ground. Check the cables at both ends to be sure that the braid(shield) is still intact and connected to the F-connector. Also, check the connections on the exterior of the house. You can also call the cable company and have them check the connections at the poles.
Dan
May 10, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
NO signal since yesterday in area SY7 0QF on Tv can not get any picture or sound was working before
If there is no signal in the area.
I mean, if the problem is extended to more than one TV set, then call the TV provider company.
If the problem is concerning cable TV (eg. NTL, Virgin), then a local node may be faulty.
If the problem is only on your TV, and the TV has no signal, or static, then check aerial, aerial cables, receiver box and signal booster if present.
If you use cable TV, check wires and receiver box.
If you have Sky TV, then check if you have sat signal, check box and cables.
If you do not find anything wrong call TV company.
If instead your TV stays off with power led on or blinking, then the TV is in fault mode (protect).
Try leaving the TV unplugged from power for one hour. If that does not fix the problem, then call the number listed on the owners manual for support, or ring a local technician.
Sep 04, 2009 | Tvone LM-1501R 15" Flat Panel LCD Monitor
HK AVR 645 7.1-Receiver Turns off when sound starts to come through
did you figure it out? I bet your problem is the same as mine NOT HDCP complitant.... its gettting a signal from the bluray that can not be accepted... research HDCP compliant... my ONKYO does the same thing...
Jul 10, 2008 | Harman Kardon AVR 630 Receiver
Lost all sound
I had the same problem. Do you have a cable box for digital TV? do you have a remote from the cable company? that is programmed to control the TV? get the cable company to unlock the sound control from it (a 3 number code) put your sound up to maximum if you can if you hear faint sound repeat above you should be able to hear the tv then then go to the sound settings and adjust as needed get the cable company to check the box in cas it has been zapped by lighting good luck
Aug 26, 2007 | Protron PLTV-32 Television
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
Yamaha HTR-5550 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
