Question about Toshiba Satellite L305D-S5881 Notebook
My touchpad does not work on my Toshiba L305d-s5881. I had to purchase a wireless mouse to use my laptop. When I press the fn key plus f9 nothing happens to bring up the enable/disable key for the touchpad
  • 624 Answers
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Posted on Feb 09, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Toshiba satellite A135-S4527
In the device manager, check to see if the drivers for the synaptic pointing device (touch pad) are installed. If they aren't then you will need to go to Toshiba's support site and download them. If they are, then unistall them and reboot. The machine will find the touch pad and reinstall the drivers. Many times when an external is used, especially for a long period os time, the drivers for the external will override or glitch the drivers for the internal. Reinstalling them should do the trick.
Posted on Jul 23, 2008
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
SOURCE: frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Posted on Jul 08, 2009
  • 23 Answers
SOURCE: Touchpad doesn't work on Toshiba Satellite 305 PSAGU-03601V
Go to
Use a mouse or Tab+Aly keys
Win XP
Start > Control Panel > System
Click the "Hardware" tab
Click the "Device" manager button.
Click the cross near "Mice and other pointing devices".
Right click, "Enable"
Vista
As above but
Start > Control Panel > Device Manager
Posted on Mar 19, 2010
How to fix frozen Asus mouse?
Press and hold down the "Fn" key on the laptop keyboard; on most laptops, it is located between the "Ctrl" and "Alt" keys.
Press the "F9" key once, then release the "Fn" key.
This shortcut disables or enables the touchpad if you ever want to add a wireless or USB mouse
Oct 09, 2014 | Computers & Internet
My toshsiba l305d-s5881 screen is black and i can not see anything when i rebootthe system
try holding down your Fn (function) key then taping the F5 key (change monitor) on startup. also you can try to plug in an external monitor to see if you can change back to laptop monitor.
Sep 16, 2014 | Toshiba Satellite L305D-S5881 Notebook
Mouse touch pad not working
'F9' keys has a mouse, no mouse looking symbol. sometimes you use the 'Fn' key in conjunction with 'F9' key, sometimes not. Give it a try by itself and use it. If not hold the Fn key and hit F9 and try again.
Jan 08, 2014 | Toshiba Satellite A355-S6925 Notebook
My mouse pad and two click bars do not work? a wireless mouse does work though. why isnt it reading my finger across the pad when i want to use it instead of the wireless mouse?
You may have it disabled. Press and hold the "fn" key then and press the key that has a symbol for the touchpad on it. For my satellite it is the F9 key. Then give it a shot. It should work.
Mar 05, 2011 | Toshiba Satellite L500 Series Notebook
Touch pad does not work
  1. Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
  2. Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touchpad, which is to control the touchpad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
  3. Now hold down the Fn key and the F10 key to enable the touchpad, in this example, the Toshiba laptops. You press them again to disable it
  4. If none of the above works, plug in an USB mouse, then check into the Control Panel -> touchpad or mouse configurations. Also, check Device Manager if the touchpad driver is installed and working
Good Luck!
Sep 28, 2010 | Computers & Internet
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
I have a Toshiba laptop. The touchpad has been broken for a while so I have been using a wired mouse or a wireless. I accidently pushed touchpad yesterday and now neither additional mouse will work. Have I...
Try pressing the holding in the Fn button and pressing F9
This should disable the touchpad, if it doesn't then you will need to disable it in mouse properties in your control panel.
Jan 15, 2010 | Computers & Internet
Hi! My touchpad mouse has stopped working in my toshiba satellite L305-S5875 notebook please help
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Apr 19, 2009 | Toshiba Satellite L305D-S5874 Laptop
Touchpad
Have you tried FN+F9? on my toshiba to reactivate glide pad I have to use FN+F9
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite L305D-S5881 Notebook Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
