Question about Polaris 3900 Sport Pool Cleaner ()
20 month old 3900 Polaris, Drive chain keeps slipping off of toothed sprocket. No teeth missing on sprocket. How do I keep chain from coming off?
  • 3 Answers
Check the float on the back of the machine. Mine was full of water. As soon as I replaced it , everything ran perfectly again.
I tried every possible 'obvious' solution, from new wheel bearings to a new chain tensioner-thingie. You will notice that there is actually relatively little room for the chain to slip off the drive gear.
Seems that this additional weight a) turns the float into a sink and b) provides enough drag to force chain slippage.
After replacing the float, everything runs perfectly again. Of course, our friends at Polaris have now decided that you cannot simply buy a new float. You have to buy the ENTIRE BACK, paying 90 bucks for something that should cost no more than 10 - 15! Scoundrels.
Posted on Jul 01, 2012
  • George Aug 22, 2013
    Just fixed my 3900 Polaris with the same problem of the chain coming of the middle sprocket. Mine is two years old. I fixed the problem by replacing the chain tensioner ($19:00). My old one showed a little wear along the inside of the wheels and was generally sloppy nthe new one lined up the chain to the sprocket by just a mm or two. The new tension kit spring is a little shorter than the original which gives the chain a tighter fit.
2 Suggested Answers
SOURCE: hello. i have a
Defect in single side wheel. It strips out causing it to run in circles. Replace that wheel
Posted on Jan 31, 2012
On my Honda 200x 1984 timing jumps one tooth after setting kicked first time ride jumped out.65.50 wisco big bore kit.12 tooth drive socket. Set tenchner til chain sound stops?,
2 questions come to mind has the new sprocket got the same pitch ( distance between teeth ) as the crank shaft sprocket as this will make the chain jump out after a few degrees of movement. A quick check is to wrap the chain around the sprocket and see if there are links that do not sit fully around the teeth. There are different pitches for teeth and chains ( BA-- AM and metric)
Nov 22, 2014 | Cars & Trucks
Hello. i have a Polaris 3900 Sport - 1 yr old. lately i notice that the drive chain is coming off of one of the sprockets, so that only the single wheel is driving and the cleaner just runs in circles. ...
Im trying to fix the similar problem...the sprocket on the gearbox is worn Part# 393-204. Unfortunately. u have to buy the whole gearbox. BS in my opinion. U should just be able to buy the sprocket...Im trying to figure how to do this with Polaris.
Apr 14, 2011 | Polaris 3900 Sport Pool Cleaner ()
Can you change tranny gears to decrease rpm's on highway? Or maybe change sprockets.
You can add teeth to the front sprocket or take teeth off of the rear sprocket. In the case of your bike , I do not think there is a 17 tooth front available so your best option would be to shorten your chain and drop from the 44 tooth rear sprocket to 40 tooth or a 36 tooth rear sprocket. That would be like adding one or two teeth to the front sprocket. Your stock is 16/44 so decrease from there. Be sure to ID your chain, get a chain breaker, and a new master link.
Feb 06, 2011 | 2004 Honda VT 600 C Shadow
My chain keeps locking up or slipping, i just put a new rim on, i tryed to fix it but now use, how will i fix it?
check to see if all chain rollers between the links are there.if one is missing then your chain can slip.What are the sprocket teeth like.are they worn?
Sep 14, 2010 | Pacific International Mongoose 26 in. Mens...
On my electric chainsaw the chain keeps coming off
Remove the bar and chain. Lay the chain out on a bench or table to check it for any sideways bending or breakage of any of the links, missing cutting teeth or drive teeth. Make sure it is being properly oiled and sharpened. Check the bar for any damaged area around the chain groove and make sure the tip sprocket (if equipped) turns freely and has no tooth damage. Check the drive sprocket for tooth damage or missing teeth. Check the drive end oil passages that run from the large holes out to the chain groove on both sides for plugging. Tighten the chain to bring it up to the bar, but not so tight that it can't be moved by hand. Hope this helps!
Aug 09, 2010 | Homelite ZR10926 16 Chain Saw
I have a Poulan 18" chainsaw. Dispite my best efforts to tighten the chain, it keeps slipping off of the bar. I can use it for about 30 seconds, then the chain slips off.
Make sure the chain brake is off (pull it toward you), then remove the bar mounting nut(s)/bolt(s) and the remove the side cover, bar, and chain. Clean the oil passages in the rear of the bar including two small passages that run from the larger holes out to the chain groove on each side. Clean the entire chain groove and make sure the end sprocket turns freely and is well oiled. Clean the engine face where the bar fits, then start the engine. Oil should ooze out of a small port in the engine case. If ok, then lay out the chain so that it can be inspected for bent links, dry/sticking joints, or missing/badly worn drive teeth. Inspect the sprocket on the clutch outer drum component for wear or damaged teeth. Make sure the pitch of the chain teeth match those of the drive sprocket (is this a new chain?). Check the hub bearing of the clutch drum for obvious wear. If all looks good, fit the chain around the clutch sprocket, then slip the bar into the the engine mounting space and work the chain over the entire bar. When setting the outer cover, make sure the adjuster tang fits into the related bar hole, then attach the clamp nut(s)/bolt(s), run up finger tight. Use the adjuster to set the chain tension--it should just pull the lower part of the chain up to the bar plus a little more. Check that you can move the chain by hand without any binding, then tighten the clamp bolts/nuts firmly. Recheck that the chain is properly tensioned. If not, re-loosen the clamp fasteners and re-tension the chain. When the clamp fasteners are tight, the tension must be rechecked. Hope this long-winded response helps!
May 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain keeps coming off.why?
Chains must not have too much slack in them. There should be about 1/2" (12mm) of vertical movement on the slack side.
It could be your have a worn out chain.. Look at the drive pinion. The teeth should have a flat top and both faces of the teeth should have the same profile. If the sprocket is very worn, the teeth become pointed and the chain does not sit correctly on the drive chain wheel on the rear wheel, (i.e. there is a gap between the chain and the inside edge of the driven sprocket.
If you change your sprockets, change the chain also (you must do this as the chain will also be very worn).
Mar 21, 2010 | 2002 Suzuki GZ 125 Marauder
Polaris transmission
first check ur sprocket and see if ur teeth look skinny if so ur sprocket is probably bad or the chain is bad see if chain feels real loose between the individal links
Feb 24, 2010 | Polaris ATV
Polaris 3900 Sport Pool Cleaner () Logo
1,769 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
