Question about Koolatron WC12G Wine Cooler
Not cooling ,light works , has power , just quit cooling . is there a restart button
Shark rocket ultra light vacuum.Quit working after over heating
-may be...
If not that mean the motor is burn or burn internal wire.
-Buy new one is cheaper than fix.
Good luck
Mai
Oct 17, 2016 | Shark Rocket Ultra-Light Upright Vacuum...
No power what do I do when I stopped and tried ti start again no power . Emptied it and cleaned filter but still not working
All vacuums generate heat and some have automatic cut off switches when the vacuum does overheat. When this happens the manufacturer does not want you to just turn it back on, they want you to know there was a problem and to let it cool down. They often do this with a restart button. Having to press a restart button is supposed to make you think a bit more about the problem and, perhaps, let the motor cool down before restarting the vacuum. The button is often small and red.
Sep 15, 2014 | VAX Appliances Vax X3 Bagless Upright...
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Old Gateway system (Desktop), Celeron 800MHz. After being on for 30min to an hour, operating system quits. Monitor displays first "no input" then "power saving" and will indefinitely keep cycling between...
sounds like its an over heating issue,i would check the fans to make sure they are all working and clean.Check that the cpu has thermal paste and that it still good(if its stiff or crumbles when you take off the heatsink it needs to be replaced)also check the memory is seatted all the way in.
Sep 01, 2010 | Gateway (683728192730) Barebone
We have a RB193ka Samsung frdige. Whenever there
hi there.....power interruptions on refrigeration apliances is to be avoided at all costs....can be very damaging....when you've experienced a power cut or interruption of mains voltage,,,,the fridge unit and or the freezer unit may have been stoped under load.....when ower is restored it can take quite a while for the refridgerator to start u again......avoid using the super cool button as this is overiding the thermostat setting of your apliance....if you require an operating manual .contact samsung at www.samsung .co.uk.. go to support for your model
regards Sir Galahad
Aug 16, 2009 | Samsung RB215LASH
NO RESPONCE-NOTHING - DEAD - CHECKED WIRES -KODAK ESP-3-WAS WORKING FINE, JUST QUIT.
take power cable and usb cable out of the printer .hold down the on/off button for 40 seconds without cables. then plug power cable and restart ur printer. make sure the green light on end of power cable is on. contact kodak @ 1800 421 6699 for further issues
Jul 26, 2009 | Kodak Office Equipment & Supplies
My Acer aspire 1680 has suddenly died. It sounded like a light bulb blowing. I cannot restart it but there is power going to the box from the plug. There are no lights at all showing on the machine. The...
you probably blew a resistor and killed the motherboard due to overheating, please contact acer for free replacement if it is still in warranty period.
Cheers
Jul 08, 2009 | Acer Aspire 7110-2069 Notebook
Rival deep fryer
try the reset button
Dec 02, 2007 | Rival CZF745 Deep Fryer
Koolatron WC12G Wine Cooler Logo
121 people viewed this question
Top Koolatron Furniture Experts
ray gallant
John Mangan
John Mangan
Tom Chichester
Are you a Koolatron Furniture Expert? Answer questions, earn points and help others
