Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer heats intermitantly and smells like gas when it doesn't get hot . Is this a bad igniter issue?
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
DOESNT HEAT AND I SMELL GAS
Hello - From what you are describing, if the dryer only heats up sometimes but provides a gas odor, it could possibly be a defective gas supply or igniter. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If it proves to be ineffective and if the issue continues I suggest contacting a professional to move forward accurately. Keep in mind since it is such a complex unit, the technician will likely verify that it doesn't have a defective sensor, control board or high limit thermostat.
Oct 13, 2012 | Frigidaire GLGR341AS Gas Dryer
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
My natural gas maytag dryer does not provide hot air to dry the clothes. It apperas the gas is not igniting because after it tries it smells like gas. I beleive it could be the ignition source.
heatman101
Jul 17, 2011 | Dryers
Dryer will not heat up.Igniter is good but will not heat up. No gas smell while dryer is tumbling.problem must be elsewhere?Please help
there is two small black solinoids near the igniter., just follow the wires. they are not opening letting the gas through the safety. or the igniter is not getting hot enough to activate the solinoids. i have seen them glow but not create enough milivolts to open the solinoids
Oct 27, 2009 | Kenmore 73952 Gas Dryer
My estate gas dryer has intermitent heat. sometimes its hot the next cycle is cool.I cleaned the vent out thourghly.every thing else looks good.what should i check.thanks
Hello. I can help you. Your igniter is on its last legs.
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Jun 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Gas dryer with gas smell and no heat
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Aug 29, 2008 | Bosch Nexxt WTMC3521UC Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
77 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
