Question about Goodman CPLE24-1 Air Conditioner
The ignitor comes on and then the burners ignite but they only stay on for a few seconds then they go out after that the same thing happens
  • 1,420 Answers
The flame rod found at the last buirner that lights is either dirty or bad. Look in the flame of the last burner for a small diameter rod that has one wire going to it. Polish it with a small brus and then try it.
Posted on Jan 01, 2011
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Burner ignitors stay on after burner is lit
Nothing bad can happen if the ignitors stay on but it can be annoying. I remember reading something about this I will try to look it up again.
Mar 26, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Dryer heat stays on for a few seconds and then
the clicking noise is the gas valve opening,but it isn't firing due to either a bad gas valve boost and secondary coil,a bad thermal fuse,or a bad ignitor bar that glows white hot to ignite the gas,or the radiant senser is weak or bad on the burner tube body
May 24, 2010 | Dryers
Dependable ninety two blower comes on no igniter glow gas flows
if you dont see the glow of the ignitor it is probably bad . you can check with a meter that has an ohms scale, unplug and test ignitor side OL would be a bad ignitor 45-110ohms ok.
Oct 03, 2009 | Goodman GMS90703BXA Heater
Glow coil glows but wo'nt ignite burner. can
if you have used the self clean function you may have burned up the ignitor they are rated for about 1000 deg for just about a minute but when you clean it stays around 800-900 deg for about an hour or so. You may just need to replace the ceramic ignitor. as for the gas, the valve will only stay open for a few seconds, if the oven doesnt recognize a flame the gas valve will close.
Jul 26, 2009 | Maytag PER5710 Performa Electric Kitchen...
No heat on whirlpool LGR4632EQ2 gas dryer
Well there are two main sources for this to happen # 1 The igniter can go bad if you can view the burner area turn unit on and watch for glowing ignitor,< takes a few seconds > if ignitor comes on and goes off without lighting burners then #2 flame sensor,< located on burner rail it attaches with one wire>, remove the one screw holding it on rail and remove,< clean it by scraping with sharp knife or something with an edge to it until it appears to be fresh metalic look. replace and try again and if this does not work then gas valve is probably source of failure.
Apr 23, 2009 | Dryers
Rheem Furnace sometimes takes a couple of ignition cycles before
Try cleaning the flame sensor. It is located right besides the last burner. Looks like a thick piece of wire. Take steel wool and gently remove the carbon that has built up. Should only take 4 or 5 strokes. Let me know how it goes after that. ken
Dec 23, 2008 | Heating & Cooling
Stove igniters stay on
Hello edmontonDad,
Welcome
You said, Stove igniters stay on.
The igniter goes off only when the cap is removed.
This is happening with two burners at the same time.
This sounds like a valve control problem!
Do not leave this go.
This can be dangerous!
Seek service right away.
SORRY that it has to be hands on service!
Thank you for using our advice.
Huuum
Please remember to leave a rating
Oct 03, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Heating & Cooling Logo
26 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
