Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
Hi, i have the Netgear N600 Wireless USB, wich works well on several routers, BUT doesn't want to connect to the MOTOROLA SBG 900 router. It finds the MOTOROLA ROUTER and prompt me to type the WEP security code of my internet provider, i type the code, then a little computer appears on my right corner of my windows XP and a message appears of LIMITED CONNECTIVITY to INTERNET. What can i do? The WEP password is the correct one.
    Novelist:
    Scholar:
  • 86 Answers
You mention "the WEP security code of my internet provider, and from this either you mean the WEB of your Router that you provided that the other devices use, or you mean something like the user name and password that you use to log into the ROUTER to set the settings for it. I'd try to help; but, it's not clear what you are really having an issue with. You should be able to check any device that uses that router and get the information needed. But, mostly devices just need to have you put in the password, in this case the same WEP used on other devices, as long as you are using the same protocol in the new device this should work.
The other issue you have is that you list the model of a Netgear Router: WNDR3400100NAS but you call it a USB, which sounds more like a NIC (network interface card). So, there's confusion over what is trying to connect to what. Are you trying to connect a device, or another router to the first router wirelessly. And that's another problem altogether. So I see three issues with your description, could you be a little more succinct?
Posted on Jul 03, 2017
hdpanama
  • 65 Answers
SOURCE: netgear wg111v2 wireless usb adapter wont acquire ip address
Not sure if this is where you are looking, but it probably is. click START then CONNECT TO then SHOW ALL CONNECTIONS then right click LOCAL AREA CONNECTION click STATUS then SUPPORT,,,
or CONTROL PANEL then NETWORK CONNECTIONS then right click LOCAL AREA CONNECTIONS then click STATUS then SUPPORT tab
See what you have there for an IP address
Is it the computer you don't have an IP for or the router? In my case my computer IP the 8th or last digit is the next number after what it is for the router. The other numbers are the same
Posted on Nov 27, 2008
hdpanama
  • 65 Answers
SOURCE: netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Posted on Nov 28, 2008
redhaze89
  • 854 Answers
SOURCE: Netgear wireless N USB adapter wont connect to my netgear router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For wireless N USB adapter
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Posted on Aug 16, 2009
anandg27
  • 1272 Answers
SOURCE: Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Posted on Sep 02, 2009
  • 89 Answers
SOURCE: I just got a NETGEAR n600 dual band router, ran
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Posted on Dec 09, 2010
How do I connect my HP Photosmart C4795 Printer to my new Netgear N600 Router?
Hello Janet,
Please click Wireless printing center to access more info on how to connect you printer to a netgear router ( wireless )
Dec 23, 2013 | NetGear N600 Wireless Dual Band Router...
HP 6400 wireless printer will not work with netgear wndr3400v3 router
If the printer is connected via wireless it may not be set up correctly, as a network printer.
Connect it up via a USB cable to make sure it works, then change it to Wireless configuration and re-install it as a network not a USB printer.
see manual
http://www.hp.com/ctg/Manual/c01325559.pdf
Sep 13, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
How do i hard reset the n600 wireless router to set the defaults
take a look at the back of the device. there is a tiny hole between the usb and the wifi button. use something suitable to push the button inside (pen, paper clip) and hold 5 seconds (until the power light begins to blink). release the button and wait for the router to boot up and you are with factory defaults settings.
def username is admin
def password is password
def ip address is 192.168.1.1
you can also access the router by typing www.routerlogin.net or .com
there is a link to the manual if you like to learn more
ftp://downloads.netgear.com/files/WNDR3400_SM_23MAR2010.pdf
Sep 19, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I recently purchased a Netgear N600 Wireless router connected to my Comcast Motorola Surfboard SB5120 modem. I have a Comcast plan of 20 Mbps but through www.speedtest.net am consistently getting 8 Mbps...
I think its the modem that you need to upgrade. Comcast is already running on DOCSIS 3.0 system. The SB5120 modem that you have is a DOCSIS 2.0 modem. You may need to have your modem replaced with a DOCSIS 3.0 modem like the Motorola SB6120.
Aug 31, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My NETGEAR N600 connects to the internet via wire. With my configuration or dealt factory settings can not get it to connect to the internet when in wireless mode- Shows Local Only! Restarted,...
Hi, You have to reset the router by at the back of the router. Use a jumbo paper clip to push the reset bottom at rear of the router close to the antenna it is a small hole. Them do the setup again and the IP address is 192.168.1.1. You have to complete the setup 1 to 5 successfully in order the router will work. The setup takes about 20 minutes if it is longer than that you are doing it wrong. Just follow the instruction and don't skip any steps. I hope this information will help you solve the problem.
Jul 07, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a Motorola SBG 900 router and I need the password for my network to connect my iPod touch
you will need to check the wireless settings of your router.
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for step by step instructions
Apr 09, 2010 | Arris SURFboard SBG900 802.11g/b...
Cant lock my signal was trying to find a alternative way because i lost the disk??? i have a SBG 900 and any one can get on my internet signal
There's another option to configure the security or encryption using your SBG 900
Connect your computer to one of the LAN ports
Access the configuration of the modem (example 192.168.254.1)
The if you got the configuration page open find the wireless settings and configure the WPA or WEP security using your modem.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
229 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
