My Coleman Evcon furnace DGAT090BDD has been acting up, it will ignite, flame will come on, blue, and then after a couple of seconds it will turn off and start the cycle again. Thought that the pipe was plugged on roof from snow, so cleared it, there was only a bit of ice hanging from the roof cap. Also changed the filters on front of furnice, thinking they were clogged up. When the front covers are off the furnice it seems to work fine, but once the covers are on, it does the recycling over and over. The furnice is not showing a code of anything wrong, so i dont know what else to do.
  • 1,420 Answers
You may have a dirty flame rod. It is located in the flame of the last burner that lights up. Polish it with a small brush.
Posted on Jan 01, 2011
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Where is my flame sensor on a single burner coleman evcon high efficiency furnace
If this is a hot surface ignition system, the sensor may also be your igniter.
Dec 11, 2013 | Heating & Cooling
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
My furnance is acting up you turn it on it clicks on then lights the flame gets big then seconds later the flames go out and the blower kicks on what could be the problem ive had several people look at it...
If the fan takes too long to come on, the high temp limit may be opening. Could be a defective limit, hard to say without more info. Another possibility is a mis-adjusted heat anticipator. A normal setting would be around .45 amp. The heat anticipator is inside the cover of the thermostat (older, analog style). Good luck.
Nov 28, 2009 | Tools & Hardware - Others
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon dgat090bdd. New ignitor won't heat up.
Looks like 4 flashes might be high limit fault on this furnace. (I don't have a manual for this furnace, just searched online for the code meaning) Is the unit running flame at all? Is the unit running flame for a while then shutting flame off before desired temp is reached? Does the main air fan turn on to circulate air through your diffusers? Does it feel like the unit has much air flow out of the diffusers if the fan is running? Is your air filter clean? If it is infact your high limit switch, it is usually caused by not having enough airflow through the furnace and overheating occurs.
Hope this helped, let me know if I can assist you further :)
Jan 16, 2009 | Coleman Propane Forced Air Heater...
1985 evcon forced air furnace no ac
Most likely your flame rod is either dirty, bad or the flame is not hitting it. It is located either to the far left or far right of the burner box. It has one wire going to it and looks like a small stick pointing into the flame. Clean it with a long tooth brush. Inspect the wire where it attaches to both the rod and the control module. Inspect the flame as it starts and see if the flame reaches it within 2 to 3 seconds from first flame. If not, you may have debris clogging the flame tray not allowing the flame to pass. If this is beyond your mechanical skills (no offence) contact your gas technician.
May 29, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
