Question about Samsung Focus i917 (8 GB) Smartphone
Brand new Samsung Focus has a cracked (?) screen. Feels fine to touch but looks like cracked lines running diagonally across if you look from the side angle. The display is really messed up. Can this be repaired or replaced?
  • rahman Jan 10, 2012
    You can try to change only the top glass panel, if the touch screen is working. check this product on eBayhttp://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
If the touch screen is working. , you can try to change only the top glass panel. check this product on eBay http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180729847565
Posted on Jan 10, 2012
    Problem Solver:
  • 5 Answers
There's a fault with a wire that connects the screen go to a phone shop and ask them to have a look or you could try it yourself by taking apart your phone and having a look at the wire running from your screen to the headset . :)
Posted on Jan 01, 2011
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Hairlines and blotches on brand new Garmin Nuvi LCD screen
If your brand new Garmin GPS doesn't look good, return it for a replacement.
Jan 13, 2014 | Garmin nuvi GPS
PS3 disc games look distorted, while other discs run fine.
oh i know this problem i have the same check the cable with the audio and video if i doesn't work send it to sony or just buy a new one
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
Diagonal lines on my screen(samsung 55" projection HDTV hcn553w)
Here's the link to the user manual; http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=32370&CDCttType=UM&ModelType=C&ModelName=HCN553W&VPath=UM/200310/20031002105141187_P55A_00054A_0410.pdf Check page 28 and 29 for convergence instructions. Give it a try to see if it makes any difference. Check page 27 for the "perfect focus" feature and see if that helps. Could you take a photo of the "diagonal lines" on the set and post it - might help? If you open a menu on the screen, does it also have the lines across, or is it clear as normal. Check page 64 for how to run the demo, and try that. Have you recently unplugged the set from the mains power supply, left it for at least 15 minutes (preferably two hours) then turned it back on? if not, try it and see if you get any change. Check page 38 for the usual video settings - play around with them and see if any significant change? Check page 39 and set the "automatic picture setting" to standard, if it isn't already, and something else if it is - see if you get a change. Check page 40 for the colour tone adjustment - probably won't change anything, but worth a play in case. Check the bottom of page 46 about channel fine tuning - reset at least a couple of channels to 00, see if that makes a difference (long shot). Does the screen itself need cleaning? recommended is just a clean dry cloth - basically have a good close look at the screen when it is both on and off, to see if there are any marks that might be causing the problem - in particular has it possibly been cleaned with a solvent or too aggressively cleaned in a diagonal direction? shine a light on it at a few angles to check, and look from a few different angles too. Check by moving or turning them on and off if any other electric or electronic items near your tv may be causing the effect - speakers perhaps. Move speakers to check. A way to check other items is to totally cut off the electric supply to the whole house for a couple of minutes, except one circuit into which you can plug the TV and a picture source. See if you get a perfect picture - if so, start switching circuits back on 1 by one until it changes. Hope this helps - I think a photo would help a lot :)
Jul 16, 2007 | Samsung HCN553W 55" Rear Projection...
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Lines on the screen
i have a samsung rear projection , and it has red lines going across the screen. i put it in the back of my cuboard and went out to buty a new tv . now a few months on i got it back out to have a play with it and i coverd up the red bulb with something fireproof and now the picture is great again just that there is no red anything that is red looks a bit darker. its not great but a least its some use now and i use it in my bedroom. it mite not be much help but a least i dont have to keep it in a cuboard anymore.
Mar 15, 2007 | Toshiba 53H71 53 in. Rear Projection...
Samsung Focus i917 (8 GB) Smartphone Logo
388 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
