FixYa.com
Tags:
Processors
Generic problem for all Processors
Gigabyte Model GA-7DXR Motherboard
posted by maine12 on Jul 08, 2008
Ram Overvoltage transistor on motherboard shorted. Require replacment spec P/N to order replacement transistor.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 28, 2008
Not Rated (0)
jonep
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
hi i have aGA-7DXR motherboard iin a comp o use for the grandchildren. it has ben working ok, but on moving it , it it now powerless. i believe this is because the power sw connection has come off the motherboard. can anybody tell me where to plug it onto the motherboard.
regards
john peatman
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 12, 2008
Not Rated (0)
Darth_Venom
Rank:Guide Guide
Rating: 85%, 5 votes
This unfortunately is a very common problem with eMachines computers built between 2001 thru 2005 especially those with 478 sockets (processor-P4/Celeron) & 462/A sockets (processor-AMD K7) & Intel OEM (Original Equipment Manufactured) Motherboards. I assume your motherboard is the original OEM? In cases like this it's usually time to replace the motherboard. A new one will have this problem addressed and corrected. However, if you like to 'tinker' I will share with you how I usually solve this problem when my customer doesn't have the finances for a new board as many of my customers are retirees and not in too much of a hurry. This may sound ridiculous to some but I assure you it does work and My own machine #3 in my personal network can attest to it for the last two years.
First and most important you must identify the exact transistor that has the problem. Usually there are 3-5 depending on the motherboard that control the memory circuit. Assuming you've done this you will then need to find another used Intel motherboard of comparable design that's not working and is going to be or has been discarded which you can usually get for free. Don't worry it doesn't need be an exact match as your not going to be robbing your replacement from it's memory control. Once you've located the appropriate 'scrapped' board look around it's area in between and toward the it's rear across from the "Northbridge" for where the front audio is or where it's cables would plug in for a comparable transistor to yours in size, contacts, solder points, etc both on front and BACK of the motherboard. Once you have located an appropriate replacement remove it carefully heating each solder point just enough to remove it so as to avoid overheating. Replace your shorted transistor with this one and you should get your video back.
Don't worry you have nothing to lose! As I stated above in cases such as this it's time to replace the board. I have though replaced these transistors with comparable ones from the audio circuit's of many different boards and have had about a 75% success rate in doing so.
Hope it helps and good luck!
Comment by Darth_Venom, posted on Jul 12, 2008
You must also realize whats wrong with the memory circuit on your board could be a capacitor or more likely a diode among other things. A burnt out diode is more likely to cause a short (which can burn a transistor) and in most cases it must be located and replaced also to avoid the situation from repeating itself. The above possible solution ONLY works when you can identify which transistor & possible related components that are causing your problem.As stated normal proceedure when this happens is to replace the motherboard.
This demonstrates just how complicated an operation your getting yourself into. In all my comment/s above I forgot to say why this might help you which is that my machine #3 mentioned above in my first reply has a GigaByte Motherboard (GA-8ID533) and it has been working non stop now for 2 years and about 3 months since I replaced it's most upper transistor on the right side of it's memory modules and two of the diodes near it that were painstakenly located after a few trials and errors. Before and since it's resurrection the only machines I have had this type of trouble with (and there were a lot of them) are the above mentioned eMachines. Sorry for the confusion.
This Problem Also Relates To: HP Xeon , 2.8 GHz Processor Upgrade HP (224138-002) ( 224138-002 ) Processor Board HP (346989-B21) Xeon MP, 2.7 GHz (346989b21) Processor Upgrade HP (346990-B21) Xeon, 3 GHz (346990b21) Processor Upgrade HP (1821-2295) Pentium, 133 MHz ( 1821-2295 ) Processor HP (399889-B21) Dual Core Xeon, 3 MHz (399889B21) Processor Upgrade HP (399899-B21), 2.8 GHz (399899B21) Processor Upgrade
Can you Help with these Processors problems?
Processors
Intel processor
the processor packages that the... Answer This...
Compaq CACHE BATTERIES
Battery does not charge
I own a Compaq M2015LA Presario... Answer This...
Intel Core Duo T2600, 2.16 GHz Core Duo...
intel core duo T2050
i need a software to control... Answer This...
AMD Athlon XP 2000+, 1.67 GHz Retail...
I have an hp 7905 desktop. It...
I do not know where to find the... Answer This...
AMD Sempron Processor 64 bit 2800+* 754pin...
overclok
how to overclok this cpu under... Answer This...
Repair Service
Find Processor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
