Question about Acer Aspire One Netbook 8.9" Notebook
On switching on acer aspire one have immediately After first screen screen stating Windows could not start because following file Is missing \windows\system32\config\ system You can attempt to repair by starting windows Set up using original cd-rom Select r at first screen to start repair I don't have cd rom and gave selected f2 on initial Screen however it is prompting me for a password I do not know which password this is as I don't usually Need one. Any ideas most welcome Thanks
    Sergeant:
  • 236 Answers
Pressing F2 on startup enters the Setup Utility and a password to that has been set up on your netbook. In any case, you can try pressing Alt and F10 at startup to get into Acer eRecovery Management which can then restore the operating system to its original factory condition. Be aware that doing the restore clears the hard disk partition containing the operating system and all user data will be erased.
Posted on Feb 12, 2011
How to reset to factory setting
If you can log into windows then simply go to all programs and click on Acer Recovery Manager and follow on screen instructions, if you cannot login then you need to power on the notebook and tap Alt + F10 at the same time untill you see a notice at the bottom of the screen stating "Windows is loading files" then again simply follow the on screen instructions to run a factory default recovery.
Jun 26, 2014 | Acer Aspire 5750-6887 Laptop Computer...
How do you get to the recovery program on an acer aspire 1641WIMi?
To use Acer e-recovery please follow the following steps:
1-Plug in the AC adapter and battery.
2-Turn the system on
3-Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4-A screen stating "Starting Acer E-recovery" should appear.
(Release ALT and stop tapping F10 at this point)
There will be 4 options:
1- Restore system to factory default
2- Restore system from user backup
3- Restore system from cd/dvd
4- Exit
Apr 28, 2014 | Computers & Internet
System recovery boot
The Acer Aspire line of netbooks have two methods to restore the computer to a working state: System Restore, an application included with Windows, or Acer eRecovery Management, a proprietary application that is packaged with Acer PCs.
If errors appear when running Windows, or if the computer begins to behave strangely, first run System Restore to determine whether reverting the PC to a previous state fixes the problem.
If the problem remains unresolved, or worsens, you can use Acer eRecovery Management to format the hard drive and reload the Acer Aspire netbook to its factory state.
Navigate to the "Start" menu. Select the "Control Panel."
Type "restore" into the Search box.
Press "Enter" then select "Restore Your Computer to an Earlier Time" from below the "Action Center."
Click "Open System Restore."
Click "Next" on the "Restore System Files and Settings" screen.
Select a restore point that was created when the computer was functioning properly. Click "Next," then click "Finish."
Click "Yes" to confirm.
Windows will perform a system recovery on the Acer Aspire One.
Turn on the Acer netbook. Hold down the "Alt" and "F10" buttons simultaneously on the boot screen to load Acer eRecovery Management from the recovery partition.
Select "Restore Operating System to Factory Defaults" from the options.
Click "Next" to recover the system to its original state.
Acer drivers and Manuals downloads
http://us.acer.com/ac/en/US/content/drivers
Jul 16, 2013 | Acer Aspire 5050-3242 Notebook
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
How do i restart my acer aspire 5290 laptop back to factory settings. it has a virus and i want to delete it all back to factory settings
You need to reformat your laptop then reinstall everything. When doing this, you need:
  1. You OS Installer (Windows needs a valid CD-key)
  2. Motherboard Installer (This CD/DVD Installer is usually shipped with your laptop when you bought it. This CD contains all the required drivers to make your laptop works perfectly back to its original state.
  3. If all these installers are ready, insert the Windows CD installer and restart your system.
  4. It will start a setup program on DOS mode. Just follow the on-screen instructions. Make sure that you "Delete" the existing partitions and "recreate" them. It will then format the drive and start the installation.
WARNING: Formatting your drive will delete all your personal files as well. Make sure that you back up all necessary files before doing these steps.
Mar 01, 2010 | Acer Aspire 5920-6706 Notebook
Im having a prob with my acer aspire 5920.when i srtated it, d screen says, "windows failed to start. A recent hardwareor software change might be the cause". then further down the page it states if...
Follow the online instructions because this will help repair the problem, then logon the internet and perform a windows update at the microsoft website
Aug 19, 2009 | Acer Aspire 5920-6727 Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Can't access any programs or download or anything on my desktop a
If you have a Recovery Partition .. you can access it by powering on while holding the F-10 key... (some models use a different F-key)..There you can restore or recover windows.. If no Partition exists, you will need a windows OS cdrom and boot to it, at the first screen it stops at, press R to get to your Repair Utility Screen.. Choose the Proper Hard Drive Partition From the choices given, and once it gets to the prompt... type fixboot.... when that finishes, type fixmbr... reboot..
Feb 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
Restoration disk
Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
1. Plug in the AC adapter.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
4. A screen stating "Starting Acer Erecovery" should appear.
5. There will be 4 options:
1. Restore system to factory default
2. Restore system from user backup
3. Restore system from cd/dvd
4. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
1. If recovery cd/dvd's were created, they can be used to restore the system.
2. Insert disc 1 and follow the prompts.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire One Netbook 8.9" Notebook Logo
278 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
