Question about KitchenAid Refrigerators
Kitchenaid KSRS25IKW01 SxS Water is leaking from bottom of fridge during defrost cycle
    Genius:
  • 1,196 Answers
Water from the bottom of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan, or a clogged defrost drain pan.
I will advice you check these area to fix the problem.
Posted on Jan 01, 2011
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Water drip from water dispenser
Hi
Probably a bad water solenoid in the back of fridge. Also, could be low water pressure to it. When replacing it, check the water pressure by losing the line to it and verify "decent" pressure.
Also a faulty water inlet valve can cause this. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Please check this link for some useful information:-
http://appliancejunk.com/forums/index.php?topic=2599.0
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | KitchenAid Superba Architect KSCS25INSS...
The freezer is leaking water out the bottom model #ksrg2tfkst18 kitchenaid
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | KitchenAid Refrigerators
Finding water at bottom of fridge
Most probably the water can be the overflow from the drain tank of the fridge to which the auto defrost condensation flows. Also if there is any leak onthe tubing from the evaporator tray this can happen.
So remove fridge forward and check,
Sep 22, 2010 | KitchenAid Refrigerators
Water is leaking from the bottom of the fridge.
Your fridge has likely gone through a defrost cycle. What frost was present has been melted and drained into the tray. During this cycle, the walls of the freezer are warmed up as well to facilitate melting the ice.
The air blown from the condenser fan should be blowing across the collection tray, and will evaporate the water in a short time. If you think that there is too much water, or it has started to over flow the tray, you can try scooping the water out using a small cup, or place the corner of a large towel into the water to soak it up. In either case, turn off power to the fridge first.
Jun 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
The refridgerator has large amnts of water leaking from freezer
Looks like your defrost element is bad and needs replacement. Or if you can do a manual defrost and check if you are getting heat on the element. If there is heat, you can find a piece of copper wire and wind it around the element, leaving a trailing length of around two centimeters into the outlet drainpipe. By conduction this should keep the drainpipe clear.
Jul 02, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Kitchen Aid bottom freezer has frost/ice buildup
Do you know for certain that the automatic defrost cycle is running at all?
Depending on the model, it should be entering the defrost mode every 12 or 24 hours. If the defrost timer is not easy to see (because of the drawer construction), you should be able to catch it by checking the walls of the freezer at random to see if they are still 'ice' cold or more temperate.
You may definitely have a leak, no argument there, but the defrost cycle may have been masking it while it was still happening by sending the ice/water down to the pan.
Jan 18, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Refrigerators Logo
78 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
