I can't get the cartridge to move to the center so that I can take the old one out and put in the new one.
    Problem Solver:
  • 8 Answers
*Not a solution, yet.*
Please list the made and model of your printer.
Posted on Jan 01, 2011
I want to relace my cartridge with new one but it cant open the cartridge. the cartridge holder didnt move to the center. what should i do?? please help
Make sure the power to the printer is turned "on" ; when you lift the cover to the printer cartridge housing, the cartridge carrier will move to the center of the housing making it accessible to remove the old cartridges- then insert the new ink cartridges after properly removing all the packing tape from them..
Nov 23, 2013 | Canon PIXMA iX4000 InkJet Photo Printer
How to get old ink cartridge out
I dont have this printer but most are the same! If you open the front door the cartridges should move dead center on their own. If there is a plastic colored bracket on top, just pull straight up. Then pull the cartridge towards you! Should pop right out! When putting the new one in, the bottom goes in first!
Aug 16, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do i put new ink cartridge in
The printer must be ON. Open the Front Access Door of the Printer. You should see a Carriage ( the part that holds the cartridges ) move from left to right. Wait for the Carriage to Stop ( usually in center ).
Open the packaging tape from the cartridge and slide the cartridge inside the Cartridge slot. Insert the cartridge from below and Push the cartridge upwards to snap. You will hear the snap sound.
Close the front access door and wait for the Cartridges to be aligned. After the printer has printed alignment sheet, Place it face down on the Scanner glass and press OK button.
The alignment will be complete.
Regards,Suhail
Dec 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
Hello, just today my printer (HP Officejet 6310 All-In-One InkJet Printer) showed an error saying , "Cartridge Error: Cartridge in the left must be replaced. I put ink on both , just in case that was...
You need to decide upon a suitable replacement. HP recommends using their ink cartridges, but you can also choose to use a cartridge from a different brand. If you have a higher volume of prints, you may even consider refilling old cartridges to cut down on costs.
Remove the old cartridge by removing the main cover. The cartridge carriers will automatically move to the center. Press the top of the carriers to open the plastic lids covering the cartridges. Gently press down on the old cartridge and slide it out.
Install your new HP printer ink cartridge. Remove the blue protective strip from the contacts and place the cartridge in the carriers. Press down gently until the cartridge sits in its position. Replace the carrier lid and main printer cover. Restart the printer and take some test prints.
Nov 17, 2010 | HP Officejet 6310 All-In-One InkJet...
Epson c20ux -ink cartridges installation
Power on
Open door or front top of cover that covers cartridges.
Systen should move ink carrage to center so you can take out old and put in new.
Close door/cover and should get some data on Monitor to follow so system recognizes new cartridges.
If no work u have some type of a problem in printer.
I'm assuming you don't have a paper jam or anything. If you do must clear.
Luck
JC
Jan 18, 2009 | Epson Stylus C20UX InkJet Printer
Instaling ink cartridge
Open the printer below the scanner bed. Lift up immediately above the keyboard area. This opening is immediately below the opening for the scanner bed. If you have the printer on, the cartridges will move to the center. There is a legend in front that shows you which is black and which is color after you open the printer. To take out a cartridge, push the aqua latch immediately in front of a cartridge. A top cover to the cartridge on springs pops up. You can gently pull a cartridge out of its housing. If you are replacing a cartridge, remove any orange pieces from the new cartridge as needed, remove any tape covering the copper sensors, then put the new cartridge where the old one was and push down on the cartridge spring-loaded housing cover. Repeat for the other cartridge as needed. When finished and the housing covers are closed, close the printer and the printer will move the cartridges where they need to be. Use the printer's software to align cartridges as needed. You should be good to go!
Jan 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
My ink cartridges won't move to the center when I open the printe
Be sure the printer is powered on as it needs power to move the cartridges - this is a common mistake.
Dec 18, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
Ink cartridge
you have to on the printer. Then you open up the front cover, the cartridge place will move to the center of the printer.  push the lock button of the cartridge and you may remove the old cartridge. You have to remove the old cartridge and change with the new one.
May 06, 2008 | Lexmark Z600 InkJet Printer
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
