Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
How much should a starter on a 3020 diesel tractor draw. the batteries only turn it over for maybe 20 sec. the starter was new a year ago
    Sergeant:
  • 223 Answers
Does the starter get hot? In 20 seconds of use it shouldn't get more than toasty warm.
If the starter isn't heating up excessively I'd think the next thing to consider is the batteries. They don't last forever, and heavy use when starting can just wear them out to where they have a short cycle under heavy load. Check the electrolyte in the batteries too, low electrolyte will cause a battery to act just like a smaller battery than it is.
How does it run? Any smoke at idle, that sort of thing? If the pump timing is late it can make for a hard-starting motor. Is there any leakage in the fuel return that could cause the injector pump to be losing its prime? Are you getting good thick white smoke from the exhaust right from the time you hit the starter?
Honestly, 20 seconds of cranking is a lot for a diesel.. Cranking speed can be critically important in starting a diesel, and you get the best cranking speed in the first few seconds. If this motor has glow plugs go through them and make them work. If you can park it near an outlet put a block heater on it and stick a cheap hair dryer in the intake when you start it, you wouldn't believe how well that works.
If there's no way to warm it up then you gotta ether it. A can or two of ether a month can save you a lot in starter wear and hard battery use. The trick is to use as little as possible- you want it to fire smoothly with no knocking. Heating your ether can on the defrosters helps some too, just don't forget it there..
Give all this some thought, get back with me and let me know what you've tried and how it's working for you, we'll take it from there.
Posted on Jan 01, 2011
Starter turns to slow to start new battery new starter cables good starter gets hot
ck to see if your engine has a compression release to allow it to start , they work by oil pressure on exhaust valve , low at first start and high at end of start cycle , this could be cause of this happening , also diesels need to have at least 12 rpm before they start (turn fuel on) , so starter /battery needs to be spot on for it all to work
Jan 21, 2016 | Diesel Garden
What does the battery of a tractor have to have if the tractor is a diesel, when trying to crank it?
you need to run a draw test at the starter to see what is really getting to the starter ( run amp draw an voltage test)
Aug 06, 2015 | Cars & Trucks
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
Have a Mitsubishi starter for a small 3 cylinder (Toro Mower)
Removed starter and tested with new battery and jumper cables...starter worked fine. Replaced battery and cleaned cable attachments...unit started as usual.
When starter throws this would indicate that the interconnect circuits are intact..the engine still would not turn...that leaves the battery, the cable, or a siezed engine. The engine flywheel turned easily...no siezure. That left only the battery and cable. Battery was 3 years old...cable was corroded...bad combination. Battery was replace and corrosion removed from the cable terminals...started first crank.
Apr 12, 2009 | Diesel Garden
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
258 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
