Question about 831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS
Car keeps grinding when start with remote car starter or with key, then take starter wire from remote starter to vehicle wire then everything works fine.
    President:
  • 1,796 Answers
Hi!!
Relays are activated when they receive a Positive (+) or Ground (-) Signal depending on the system design, in the case of the Starter Relay, the signal comes from the Ignition Switch when turned to the START position. The remote starter also sends the same signal to the Relay to activate the Starter and CUTS it OFF when the Remote Starter Module receives the signal that the engine is running. In this case, the Relay signal does not CUT OFF and keeps sending the signal to the Starter, usually this signal is send by a Relay integrated and controlled by the Remote Starter Module. I believe this relay is defective and getting sticky, reason why the Starter keeps running after engine starts. I suggest to take vehicle to an Alarm Shop and let them fix your problem.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Jan 05, 2011
Viper remote starter won't start the car even with a New key fob battery, it will crank for about one second then nothing.The car starts with the key and the door and trunk locks work with remote fob
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
Feb 26, 2018 | Cars & Trucks
I have an autopage remote starter that worked just fine until I replaced the battery in my vehicle. The remote still works, everything still works except it runs for about a minute, shuts off, restarts,...
sounds like security system is keeping it from running. try this. disconnect the battery again. lock the drivers door with the key. reconnect battery, unlock drivers door with the key and try and start the car with the key. does this work?? ok now shut car off and lock it and try remote starter. hope it works it just might
Dec 03, 2017 | Cars & Trucks
Viper 5101 no longer starts
are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
Apr 17, 2014 | Remote Start System
When I try to use my automatic start on my viper sst my car wont start up.
The Remote start is hooked up wrong. They have the power for the starter connected to the wrong wire. Its not reading that the car has started and when you put the key in it recognizes that its running. Take in it to who ever installed it and have them change those wires around.
Nov 09, 2011 | 5900 SST 2-Way Security System / Remote...
Have a Ford transponder2 in a Nissan Xterra when I hit the remote starter the engine turns over but will not start. When I take the key out of the transponder wire coil and put it back in the car will...
So, this is a transponder key box, correct? And, the vehicle starts with the remote starter when you put the key in the ignition but, the vehicle will not start when you put the key in the key box, correct? If what I have explained above is the issue, there could be one of several problems. The key box may not be getting power and/or ground when running. Test to make sure. Next, the antenna ring going to the ignition cylinder may need to be adjusted to insure that the signal is being received by the vehicle. Next, if the vehicle starts with key in the ignition; also test that the remote starter works with the placed by the ignition cylinder (without being placed in the ignition). If the remote starter starts with the key IN the ignition but not with the key being placed BY the ignition cylinder, you may need to activate the key sense wire during remote start.
Jan 15, 2011 | Code-Alarm Code Alarm Transponder
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
Starter stay engaged after it starts
If your starter stays engaged after the vehicle starts with the remote starter then, the vehicle's starter wire is receiving 12 volts, most likely from the remote starter's ignition or accessory wires. Check the connections to the vehicle's wiring: the battery wire is constant 12 volts, regardless of key position. The accessory wire(s) is 12 volts with the key at accessory and on/run (position 1 & 2), the ignition wire(s) is 12 volts with the key at on/run and start (position 2&3), and the starter wire(s) is 12 volts with the key in the start position (position 3) ONLY. Make sure that the remote starter wires are connected to vehicle's wires as directed by the Bulldog instructions.
Nov 17, 2010 | Remote Starter with Keyless Entry
I have a prestige remote start alarm. When i try the remote star, it does not turn on and makes the noise (melody) it would make when i would turn it off. 2000 Chvrolet silverado
Could be several causes for this...most likely there's a safety check feature that keeping the remote start from activating. Most remote start systems have a shutdown diagnostic feature that will indicate why the system is immediately shutting down before the remote start is activating. Check in the installation manual towards the back for how to initiate the shutdown diagnostics for your particular model. Some basic things that would keep a remote start from working would be the brake wire connected incorrectly, an improperly installed hood pin, no tachometer signal programmed, or improper starter wire connections. If everything seems to check out ok, put a voltmeter in the yellow 12 gauge wire at the ignition harness and see if you get 12 volts during both crank with the key and crank via the remote starter. If you don't get anything during crank with the remote starter than there's an underlying issue that needs to be addressed first to pinpoint the exact problem. Email me if you have any other questions, jared@underground-audio.net
Nov 17, 2010 | Prestige Remote Start
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS Logo
227 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
