Question about Samsung SyncMaster 220WM Monitor
I have a syncmaster 220wm, the monitor display the image for few secs after powering and then goes blank. the light stays on. pressing the source power will turn image back on, but few sec later it will turn off again. but light still stays on. any idea?
jemmyrash
  • 180 Answers
SOURCE: Samsung 191T
No !
Posted on Apr 21, 2008
  • 7 Answers
SOURCE: syncmaster 226bw goes black
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Posted on Aug 26, 2008
  • 55 Answers
SOURCE: Samsung SyncMaster 243T blacklight
i think you use tft monitor and after you plug it then lite appear and after few seconds it's gone. plz check the inverter circuit of tft monitor. and may be possible that the life of Flurocent tube is over. if you are not hardware engineer then plz tell any hardware engineer to check the your tft monitor.
thanks
Posted on Nov 13, 2008
SOURCE: I have a SyncMaster 220WM and it periodically goes
It's most likely your video card. I had the same problem with that monitor and replacing the video card solved the problem.
Currently using EVGA GeFGorce 8800GS card and working fine.
Posted on Aug 18, 2009
oldrogers
  • 53 Answers
SOURCE: Syncmaster 910t blinks image perfectly once and goes back to black
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
Posted on Sep 09, 2009
Need service manual for Samsung 220wm monitor
Download From Google ..Exemple Type Download Samsung SyncMaster 220WM Manual
Oct 07, 2010 | Samsung SyncMaster 220WM Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
VG 181 displays page then goes blank
Look to see if you do have 12~18vdc feeding the backlight inverter board (located on the left side of the monitor), it can also have blown fuses on the inverter board. Post back what you see inside so we can guide you further, this is really old monitor, 2002.
Feb 15, 2010 | ViewSonic VG181b 18.1" LCD Monitor
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Samsung SyncMaster 220WM Monitor Logo
96 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
