Question about U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel
What does the error code "r-5" mean for a Uline Beverage Center drawer unit that has stopped chilling?
5 Suggested Answers
  • 286 Answers
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Posted on May 15, 2009
  • 286 Answers
SOURCE: Uline beverage fridge loose door handle.
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
Posted on Jun 08, 2009
mgprice
  • 744 Answers
SOURCE: freezer works great , but refer does not cool,
Hi, With the information you supplied I’m going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
4462625.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
f218caf.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board2.gif normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
a4183d8.png Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Posted on Oct 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Uline 2075DWRRSS stopped working.
Sounds like you have found the source of your problem. Yes,tighten all wires and wrap them with a zip tie.
Posted on Aug 03, 2011
My U-Line beverage cooler is indicating an E5 error code and the unit will not get cold. What is this telling me?
I am not familiar with this unit but in guessing but I would not assume the thermistor is bad, actually if as you say the compressor is running that is all the thermistor can do. My first guess is the condenser needs cleaning, that is the area where it gets warm. If that is clean then the possibility of a refrigerant leak is there. If not that then the compressor most likely has a bad valve in it. I would suggest contacting a refrigeration tech after everything has been cleaned and it still does not cool.
Dec 19, 2014 | ULINE U-Line 1175BEVS-00 1000 Series 24"...
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Chill parts weber
I have call 973-492-3253 nyyankee690@aol.com
Sep 16, 2013 | Weber Chill 05-161 Beverage Cooler
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
I am getting a flashing message E5 where the temp is normally displayed on my U-Line Beverage Center. I could not find info in the manual on this code?
E5 means that the unit is 10 degrees warmer than the set point for more than 12 hours. You may need service to help you find out if its a sealed system or maybe a thermistor in the wrong location
Sep 28, 2009 | U-Line 2175BEVS-01 Uline Beverage Center...
Hi
Jun 06, 2009 | Refrigerators
U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel Logo
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
