Question about Toshiba Computers & Internet
I loaded windows 7 in my computer and i lost my webcam and other toshiba devices
  • 193 Answers
You have to reinstall the drivers for the webcam and other devices as the data gets formatted when you reinstall an operating system make sure that next time you reinstall/upgrade a an Operating system, you take back up of your drivers.
Posted on Jan 02, 2011
Why do not may toshiba webcam work proprly
How can fix my webcam TOSHIBA FORUMS
How can I fix my webcam? Question When I try to use my webcam, it doesn't work properly. How can I fix it?
Answer Skip this and contact a professional
If you'd like to skip this guide and contact a professional, CLICK HERE.
When you attempt to use your camera, you might see an error such as "Connect a camera" or "Web camera initialization failed," or the camera might simply not work correctly.
There are a few easy steps to troubleshooting and fixing a malfunctioning webcam. Each step below might fix the problem. After each step, test the webcam. If it works, stop troubleshooting. If you don't want to go through each troubleshooting step, you can skip to the "System Recovery" section.
Check Device Manager
Open Device Manager. (In Windows 8, hold the Windows key and press the 'x' key to open a menu in the lower-left. Select "Device Manager" from this menu. In Windows 7, search for it in the Start Menu's search field.) There should be an entry titled "Imaging devices" that can be expanded. The webcam should be listed under Imaging devices. If it's listed, continue to the next troubleshooting section. If it isn't there, try slowly closing the laptop while continuing to watch the Device Manager. If it suddenly appears, it indicates a hardware failure and a repair would be needed. If it never appears, continue to the next section.
Reinstall Software
Right-click the camera in the Device Manager and select "Uninstall," then restart your computer. The computer should reinstall its camera driver.
If that doesn't work, check the Toshiba support site for an updated camera driver. For instructions on how to find your downloads from Toshiba, please see the following Knowledge Base article.
Finding downloads and support documents at support.toshiba.com
Look under the "Camera" category, and download the appropriate one for your version of Windows. Some laptops may not have one listed. This is fine, as many models don't use a specific camera driver, allowing Windows to provide the driver.
Check the UEFI or BIOS Settings
Some computers have the option of disabling the webcam in the UEFI or BIOS settings. Ensure that's it's enabled by performing the following steps. Note that some computers might not have this setting.
  1. Turn your computer off. If your computer uses Windows 8, hold SHIFT while seleting "Shut down" to perform a complete shut down.
  2. Start the computer.
  3. Begin tapping F2 when the TOSHIBA splash screen appears to enter the UEFI or BIOS settings. On some models, you might need to hold F2 while booting. If you have trouble entering the UEFI settings, please see the article titled How To: Enter the system BIOS or UEFI in Windows 8
  4. Select Advanced
  5. Select System Configuration
  6. Select Web Camera.
  7. Ensure it's set to Enabled.
  8. Save and exit.
System Restore
Try using the System Restore utility to restore the computer to a working state. Select the most recent restore point from before the issue arose.
How To: Understanding System Restore, Refresh, Reset, and, Recovery options in Windows 8 + Video
How To: Perform a system restore in Windows 7
Uninstall Other Webcam Applications
Uninstall any other applications that use the webcam besides the pre-installed Toshiba camera application. For example, uninstall Skype if it's installed. This is just a temporary troubleshooting procedure. If uninstalling the other applications doesn't fix the problem, reinstall them. If it does fix the problem, try reinstalling them again to check if the webcam continues to work. If it stops working again, the issue is that specific third-party application.
Contact a professional or perform a system reset
Lastly, you might want to return your computer to factory default conditions. This is sometimes called a system reset or a system recovery. Note that this will remove all of your software and data that you added including applications, documents, photos, etc.
How that helps good luck.
Feb 24, 2015 | Toshiba Satellite C655-S5212 Laptop
I loaded windows 7 and lost use of webcam
click start right click on computer select properties device manager scroll to image devices expand if you see a yellow question/exclamation mark ? ! or a red X the driver will need to be installed right click on it select update driver
hoope this helps
Nov 19, 2011 | Toshiba Satellite L305D Notebook
I have a built in webcam in a toshiba laptop and it keeps saying now that webcam driver open fail,how can i solve this problem
According to technologyquestions, try this:
1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera (Or whatever the name of your model is) and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select USB Video Device from the list, and click Next.
7. If the message "Windows encountered a problem installing the driver software for your device" appears, click Close.
8. Restart Windows.
May 08, 2011 | Computers & Internet
Error: Webcam driver open fail. Problem with Satellite A305D
sounds like driver related problem, download this tool: Driver Update Software for XP Vista 7 8 update your drivers, and won't be any problem.
Jim
Jun 15, 2010 | Toshiba Satellite A305-S6845 Notebook
The web-cam is not working. I only get "web-cam driver open fail. Please restart camera or computer". I have dine this many times without success.
Re-install the driver for the webcam.
Follow these steps to re-install the driver for the webcam. You will need to be logged in as an Administrator or have an Administrator password ready. 1. Click the Windows Start button. 2. Click Control Panel, System and Maintenance and then Device Manager. 3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver 4. Select Browse my computer for the driver software. 5. Select Let me pick from a list of device drivers on my computer. 6. Select USB Video Device from the list, and click Next. 7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close. 8. Restart Windows. The webcam should now work properly.
Thanks
Jun 14, 2010 | Toshiba Satellite A300-0CF035 Notebook
Toshiba Built-In Webcam problem.
Goto my computer icon on the desktop and right click on it and choose properties, from there find device manager, in there look for imaging devices, click on the <+> sign and then right click on the device it brings up and update driver, choose the internet once option and wait a bit for the driver to be installed may take a few minutes so be patient.
Jan 22, 2010 | Toshiba Satellite A200-S18X01G Notebook
My toshiba L310 laptop webcam dosenot work & that happend after i upgradded my OS from Vista to win7
1. It's a driver compatibility problem with Windows 7.
2. Install the driver for web camera which is compatible on Windows 7 using the bundled CD/DVD.
3. Update the web cam driver using Windows Update!
4. Restart the system.
please rate this advice if it hepls...tc! :)
Nov 01, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Lost CD for Veo Webcam 303vs24x001832 and need to install again on computer. Where can I get a free download of the software?
I lost CD for Veo Webcam 303vs24x001832 and need to install again on computer. Where can I get a free download of the software?
Jun 14, 2009 | Veo Connect Webcam
LAP TOP CAMERA
8. Restart Windows.
You can check this link
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1924621xml&sliceId=&dialogID=36590569&stateId=1%200%2036586710
You can update the drivers here
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1596141&rpn=PSAD6U&ct=DL&BV_SessionID=@@@@1918347540.1210491665@@@@&BV_EngineID=cccjadeedgmlddhcgfkceghdgngdgnj.0
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
308 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
