My 4dtv will not power up or light up i wire came off and i reconnect the wire but it want come on now
I have code on my 4dtv 8.8.8. I dont know what is that need help
Posted on Jul 22, 2009
My garage door light stays on all the time after opening or closing the door.
The light can stay on for a number of reasons .. especially depending on how many features your opener has. If your opener has a lot of features ... take a look at your owners manual and some feature may have been inadvertently activated that keeps the light on.
However ... if everything is set up correctly try the following to help narrow your root cause down.
If you can change the delay time of the light ... reset it to the lowest time value which just helps in troubleshooting. Most are set for 4-5 minutes which is along time to wait if your troubleshooting.
  1. Disconnect power from the unit, and disconnect door control wires from the opener.
  2. Reconnect power only. Light(s) should come on. Allow light(s) to cycle off.
  3. If light(s) turn off after delay time, the problem lies with either the door control or wiring. Continue with next step. If the light stays on, it is the logic board.
  4. Disconnect power from unit. Remove door control from wall, connect to operator via a known good short pair of wires. Reconnect power only. Light(s) should come on. Allow delay time for light(s) to cycle off. If light turns off, it's a wire issue. If not, the door control should be replaced.
Mar 16, 2018 | Building Materials
Light On Ceiling fan quit working and i have a green wire hanging
The green wire is a ground wire and the fan and light should function without it connected.
You can attempt to reconnect that wire, turn off the power to the fixture at the power panel. Drop the base of the fan (typically 3-4 screws around the base) then reconnect the green wire to the inner base, you should notice a screw that doesnt actually connect anything or hold anything together and that would be the screw the green wire attaches to. If you do not feel comfortable with this I would suggest hiring a qualified electrician to diagnose and repair the fixture.
Oct 18, 2013 | Cell Phones
Dell dimension e510 flashing amber light USB front panel
If you are comfortable around computers, you could try the following to test the power supply. Unplug the cord from the power supply, hold the power button in for about 15/20 seconds, open the case, unplug the 24-pin power connector from the motherboard and jump the Green wire to one of the Black wires, reconnect the power cord and power the system on and if power supply fan and hard drive run, then the PSU should be good. Note: Do not remove any wires from the plug, use a small piece of wire or a paper clip as a jumper. Power supply checks out and the system still does not work, again remove the power cord, hold power button in for several seconds to discharge the residue power, reconnect the 24-pin connector to the motherboard. Remove all the PCI cards, the video card [if applicable], memory, all peripherals, disconnect the data and power cables to all the drives, check that the front panel cable is connected to motherboard, with nothing else connected to the system, reconnect the power cable and power the system on. If you do not get any beep codes or diagnostic lights on the front panel, then it would appear that motherboard has died.
Aug 07, 2012 | Computers & Internet
Replace oven light mgs5875bds
DISCONNECT THE POWER TO THE OVEN -----1 - Hold bulb cover in place and slide the wire retainer off of the cover ----- 2 - Remove the light bulb cover and the light bulb ----- 3 - Replace with a 40 watt appliance light bulb ----- 4 - Replace light bulb cover and wire retainer ----- 5 - Reconnect the power to the oven and set the clock
Jan 10, 2012 | Maytag MGS5875BDS Stainless Steel Gas...
Raypak 2100 265A displays GVO. I know it means Gas Valve Open, but I do not know what is wrong. It is a IID Electronic Pilot. I see a slight flame when the igniter lights and then the system goes into GVO...
Here is the directions from raypak on this code.
1. Turn off power and disconnect ignition wire and gas valve wires from cpu board.
2. Turn on the power and watch for spark at module.
3. If no spark is observed, turn off power and replace the board.
4. If spark is observed, turn off power and reconnect gas valve and ignition wire.
5. Turn on power and unit should fire.
if unit does not fire and code reappears, turn off power and disconnect gas valve wires from the board and remove MV,PV and ground wires from the gas valve. Clean and reconnect wires.
7.Plug the gas valve back into the board and torn power on. Unit should fire.
8. If the unit fails to fire, Replace the gas valve.
Its not a good code to get. Hope this helps
Mar 21, 2011 | Rheem Pool & Spa
No power after detergent dispenser replacement
check the terminal block. thats where the power goes to the machine.could be a short ot burnt wires.
Mar 06, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Lost the unit ID in a 4DTV C Band Motorola
this means the digicipher board needs to be changed and this can be expensive almost the price of refurbished one - and another reason is the battery is dead or weak
Jul 10, 2009 | Motorola Televison & Video
How to wire back of 4dtv 920 gi receiver
see skyvision web site in connecting your 920 or call 1800-500-9279
Apr 03, 2009 | Motorola Televison & Video
How do I decipher the SN on a Motorola DSR922 receiver.
The DSR922 was made from 2001-2007. No more being made from motorola ;-(
The seventh digit from the left is the date code.
So a 4 in that place means manufacture date of 2004.
Jan 29, 2009 | Arris DSR922
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
