Question about Ovens
No sure if the temp. is in C or F - Ovens
  • Ovens Master
  • 3,463 Answers
Most ovens are now calibrated to read the temp in C.
If you are not sure which is which on your oven, then if it is centigrade, it will go up to about 230 c on the dial, or 400 to 500f in farenhiet
Posted on Jan 01, 2011
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
My oven temp is not keeping correct temps set at 350 and acutual temp cooks at 325?? problem correction?
Hey friend, I appreciate your post!
It sounds like your Frigidaire oven could need to be calibrated. If could also be an issue with you thermostat or control panel. In order to properly calibrate your oven you would need to seek assistance from a professional. I would also recommend seeking assistance from a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Oct 04, 2014 | Frigidaire Ovens
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
F-2 error on digital screen, mAYTAG GAS OVEN, SELF CLEANING not sure model #.
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 31, 2011 | Maytag CWG3100AAE Gas Oven
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
Takes for ever to reach temp
you may want to check to make sure both elements are working, if only one is working it will take longer to reach temp and to cook
Sep 18, 2010 | Fisher and Paykel AeroTech OS302 Electric...
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My oven won't heat to the right temp.
Check the temp censer in the oven It went bad.
Feb 26, 2009 | Frigidaire FEB27S5A Electric Single Oven
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
