Question about Olympus Mju Tough 6000 Digital Camera
How do i copy pictures off my Olympus Mju Tough 6000 Compact Digital camera's memory back onto it's memory card? I was taking pictures, but for some reason they did not save to the memory card, they saved to the camera's memory. How do I copy them onto the memory card (SD) so i can upload them onto my computer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Use the "Backup" command. See page 40 of the manual: Owners Manual User Guide for Olympus Mju Tough 6000 Digital Camera
Posted on Nov 20, 2014
Jeap
  • 114 Answers
SOURCE: Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Posted on Feb 28, 2007
jackboy
  • 2985 Answers
SOURCE: How to remote control a
Unless the camera is supplied with a remote- some high end Olympus do have this facility[The E-series for example]
You cant.
Posted on Jun 01, 2008
  • 479 Answers
SOURCE: olympus master 2 won't let me save edited images!! help?
click save as and change location and name
Posted on Apr 07, 2009
brianwhite72
  • 12 Answers
SOURCE: Olympus MJU 760 Battery dies after a couple of
First step to trouble shoot. Connect a low voltage ohm-meter to the battery contacts inside the camera. Try to turn camera on. If you get a reading, write down the number of ohms. If possible, compare this with a brand new one, if store will let you. Or call the USA distributor. If ohms number is way low, you have problems inside the camera. If number is normal, the battery is no good.
Posted on May 14, 2010
SOURCE: Transfer internal memory to memory stick. Olympus camera
Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
Posted on Dec 30, 2010
Not charging not turning on/off lens window open. Where can I take this to get it repaired? Old model but camera barely used for 1 year.
Olympus cameras have to be sent back to Olympus themselves which unfortunately they charge for, you can get the address from their website
Mar 24, 2016 | Olympus Mju Tough 8000 Compact Digital...
Olympus 8000 turns on then turns off again, wont stay on
This happened to mine suddenly as well. I bought a new SD card and presto! All better. I think these things fry SD cards, cause this is my 3rd card.
Apr 24, 2011 | Olympus Mju Tough 8000 Compact Digital...
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
Aug 27, 2010 | Olympus Mju Tough 8000 Compact Digital...
Card 'full' but no files found...olympus 1040
hi, there's a problem in your memory card and you need to do first is format the memory card into camera (if its ok to you to delete all the picture save in memory card). If the problem still occur you need to buy new memory card.
thank you and good luck my friend
Jul 17, 2010 | Olympus Stylus / mju 1040 Digital Camera
How do i set the self timer
Press the self-timer button. It's the bottom button of the cross-shaped pattern on the back of the camera, marked with a one-handed clock. Use the +/- and self-timer buttons (top and bottom) to select the setting option. After the shutter button is pressed all the way down, the picture is taken after a time delay.
"Using the self-timer" is on page 22 in my copy of the manual.
Mar 25, 2010 | Olympus Mju Tough 6000 Digital Camera
? software problem - not responding
Remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 11, 2009 | Olympus Mju Tough 8000 Compact Digital...
I just finished copying the memory card to my usb and now the camera is not functioning...it says write protected.....what do i do? is an olympus 6000
There is a small switch on the left side of the memory card. Slide it up and the card will work. On my SD card it is yellow.
And then insert it back and check Let me know if this will help
Nov 29, 2009 | Olympus Mju Tough 6000 Digital Camera
Olympus mju digital 600 - picture card
Buy here a compatible memory card for your camere: 2GB High Speed SD Memory Card
Nov 29, 2008 | Olympus ? DIGITAL 600
Olympus Mju Tough 6000 Digital Camera Logo
121 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
