Question about Kenmore Progressive 35922 Bagged Upright Vacuum
I have a Model 116.35922500 Kenmore upright vacuum cleaner. It makes a loud air noise when using the vacuum. I have disconnected and removed the hose to see if anything is lodged in the hose and it appears clear. It makes the noise when the hose is connected. When I remove it, the noise stops. When I place my hand over the hose, the nose re appears. I sounds as though the noise is coming from the fan or internal parts of the machine. So, when there is a load or pull on the machine, it makes the noise, and not when there is no load. Thoughts?
SOURCE: Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Posted on Apr 08, 2009
reddevil6
  • 1673 Answers
SOURCE: Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Posted on Feb 13, 2008
  • 40 Answers
SOURCE: directions for Bissell upright rug shampoo vacuum
Indeed, losing directions can be quite frustrating. Below, I did some research and found a website which has most Bissell Vacuum cleaner manuals and directions online
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_product_list.html?s=gg314159
Hope this helps.
FerrariXP
Posted on Mar 17, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
MNfisherman
  • 11896 Answers
SOURCE: Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Posted on Aug 28, 2009
MY Bissell vacuum cleaner clearview makes a loud noise...what could be the problem?
first thing is check the filters. then call Consumer Care at 1-800-237-7691.
Oct 16, 2014 | Bissell 1699 ProHeat Clear View Upright...
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
A loud noise happens when I try to vacuum carpets. The hose works but that is it. Please help, I just recieved vacuum for mother's Day.
THE BELT MAY BE LOOSE. UNPLUG THE VAC AND USE A PHILIPS SCREW DRIVER TO REMOVE THE UNDERSIDE OF THE VACUUM WHERE THE BELT IT LOCATED. CHECK TO MAKE SURE THAT THE BELT IS ON TRACK AND NOT BROKEN OR SNAPPED. THIS CAN CUSE A LOUD NOISE TO BE PRODUCED FROM ANY VACUMM CLEANER. HOPE THIS HELPS........
Jun 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kenmore Quick Clean loud whistling noise from air exchange
Sounds like you may have a clog or restriction somewhere in the vacuum.
Oct 08, 2017 | Kenmore 34720 Upright Vacuum
Vacuum making loud noise (like hole in tube)
I have the same vacuum - it's a clog in the brush area, or where the hose connects to the base. Unhook the hose, like you're going to use a tool. Lay the vacuum flat, so you can stick something in the plastic tube (at the base where you disconnected the hose) without the awkward angle. I use a dryer vent cleaner, but you could probably use a wire hanger. Push through until it comes out through the brush area...should fix your problem.
Nov 13, 2008 | Kenmore Progressive Bagless Upright with...
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Kenmore Progressive 35922 Bagged Upright Vacuum Logo
451 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
