Question about NetGear WGR614 Wireless Router
I would like to password the router. I never set up the password when I installed the router. what is the best way to install the new password?
    Problem Solver:
  • 11 Answers
The password can only be changed by the management software for your router. If you do not have the network manager software on your computer, then use the installation CD or download it on-line. You must physically connect the router to your computer with an ethernet cable. The rest should be easy: changing the network name, selecting security, setting password. Good luck. Bry
Posted on Jan 01, 2011
Lost password to install linskys router,how do I find?
Hi
Reset the router using the reset button or pushplate at the back, this sets it back to the Factory Default Username and Password settings, which should be printed on the rear or underside of the router or in the manual (if you have no manual you can download a PDF manual from:
http://www.starbatteries.com/liwrwiroinma2.html
or
cna1.upc.edu.cn/cisco/tools/WRT160N_ug.pdf
Then install it again, creating a new password.
This time, e-mail the password to yourself and/or save it in your cellphone.
Hope this helps
Aug 23, 2011 | Linksys WRT160N Wireless Router
I need to know the network key for my Linksys routerWRT54GL-EU in order to establish a wireless LAN to my PC (a Fujitsu moidel) Best regards, Preben Lund prebenlund@plt.dk
When you first installed your router, you used the "Wireless Networking Setup Wizard" to"
* set an SSID ("network-name") for your network.
* set an encryption-level. Hint: use 'WPA' or 'WPA2'.
* set a password or pass-phrase for your network.
Enter that password. Or, rerun that Wizard, to create new settings.
Apr 04, 2011 | Linksys Wireless-G WRT54G Router
How to install wireless modem router N150 (DGN1000) keeps asking to install Ethernet cable want it to be wireless
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . For use wireless click on wireless then turn on the wireless or enable it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 04, 2011 | NetGear Computers & Internet
I forget my password to configure e new wireless printer
You will need the installation CD to be able to reset your password. Run the installation CD and leave the setting the way they are and when you get the point of password, enter the desired passwpord.
Nov 23, 2010 | Linksys Wireless-G WRT54G Router
Installation of belkin router failed
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 08, 2010 | Belkin (F5D5231-4) Router
New computer; can't find original installation disk
You should not need an installation disc.
Connect your PC to the router with a network cable and type 192.168.1.1 into the browser adddress bar. This will connect you to the router setup and maintenance screen, from where you can configure the router. If necessary you can reset it to factory settings and enter a new password.
You can then disconnect your cable and use it wirelessly.
Apr 09, 2010 | Linksys Wireless-G WRT54G Router
I have a Motorola SB 5101 router and the password has been forgotten. How can I install a new password. Barry
Reset the router Pressing the reset button on the rear panel. Now you must set up all again.
Feb 27, 2010 | Computers & Internet
How do I reset a password that I have forgoten
For that first press RESET button it is in back side of router.
Press it for 10 seconds.
Then connect t\router to computer with ethernet cable.
Then you can access it's configuration with http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then click on wireless then enable wep security then add new password.
Configure WAN settings as your internet service provider settings.
Enable DHCP.Then save settings and restart router.
Thanks.
Nov 03, 2009 | Linksys Wireless-G Broadband Router
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
Need help with installing the router
look for a reset on it or take it back to best buy and get a refund and do it yourself.
Jun 09, 2008 | NetGear WGR614 Router
NetGear WGR614 Wireless Router Logo
53 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
