Hitachi 50" projection TV (13 years old)
The tv will come on only if I cut the power several times by unplugging and plugging it back in and hitting the switch. Each time I hit the switch it attempts to come on and eventually does.It will then work the rest of the night. You are able to cut it on and off. The next day it will not come on without going through this process.
Holtonrl
  • Randy Holton
    Randy Holton Jul 09, 2008
    i was looking for loose connections when I discovered the on off method. I willlook further and let you know.
    rholton1
  • 6,487 Answers
The problem with your set is a power management problem caused by excessive current drain from somewhere in the set. Typical is the high voltage or deflection circuits. Your set probably does not need a new board.
Your set is not old. It should be good for about 15 to 18 years. If you want to keep it around for a while, I would suggest you fix it. I would call around and try to find someone who knows how to diagnose down at the circuit level and who has direct experience with Hitachi sets.
Hope that helps.......
Posted on Jul 08, 2008
    Sergeant:
    Champion:
  • 417 Answers
Sounds Like The Main Power Circuit board Needs Repair I Recommend taking it in for repair
  • 790 Answers
Hello rholton1!!!
Guess its a convergenge amp failure!! you gotta call the repair person. which may cost u 150-200.
Regards
Smilemaker
  • 4,234 Answers
Since the set works eventually, I would first look for poor solder connections that are causing sufficient changes in circuit characteristics to prevent startup. If you can solder, open up the back and look for any solder connections that appear grainy or have rings and resolder them. If that failes to resolve the problem, then we need to start looking at the power supply area. There could be a few bad capacitors there that are preventing startup.
Keep us posted on your progress.
Dan
  • 19,396 Answers
The switch is probably broken, you will need to replace the switch or the whole control panel.
  • Ginko
    Ginko Jul 08, 2008
    It is probably a switch problem or a problem with the control board behind the switch. In either case the repair can go over $150, in case they need to replace the whole control board even over $200. Due to the tv age, It may be worth buying a new tv.
My TV intermittently will not power on properly. Should I replace the logic board or the power supply board?
easy answer I always replace the least expensive part first. If it doesn't fix it at least you have a new part. since the logic board talks to the power board it could be either one.
May 17, 2015 | Hitachi Televison & Video
Tv won't turn on
Have a shop look at it, there is a power relay that either is causing this or something right around it is, seen this about five times over the last ten years in Hitachi sets. I had one customer who had it connected to a wall switch and from time to time had to unpower it several times but once on it was fine.....
Dec 15, 2012 | Hitachi 51F500 51" Rear Projection...
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
Hitachi 50UX53K Ultravision will not stay on
The set is going into shut down mode for avariety of reasons. Some of the more common problems are vertical o/p ic bad connection or failure, poor solder connection usually in the power or hv section or possibly comb filter circuit breakdown causing 12V line to short. This set incorporate 7 or more shut down circuits and any one of them could be triggering - more trouble shooting is required
Sep 18, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
My 50 inch hitachi projection tv keeps powering up and down.
First it is not an emergency.
No Legitimate repair company should be that busy.
Call Hitachi and get an AUTHORIZED Hitachi dealer to service your TV.
Your problem is beyond self help/
Unplug the TV until it is repaired properly or you will do more damage and have a much larger repair bill.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 50EX12BX
Sounds like something is overheating causing the thermal protection to trip.
Jul 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi rear projection tv turned off, won't come back on
Hitachis have a series o led's on the main board, mabe up to six, thesshould all light up when the set is on, o frst thing is to lookat thes LED's and see if they all light up
Jun 24, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
