Just installed a Honeywell 6350D t-stat to a heat pump system with nat gas backup. System starts the heat pump correctly, then recognizes it is not keeping up and initiates the nat gas backup, but does not shut off the heat pump compressor. Is this a wiring problem? I have a jumper from W to E, but have read some places that a jumper may be needed to Y as well?
  • 20 Answers
SOURCE: No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Posted on Jan 10, 2009
pierre1811
  • 144 Answers
SOURCE: replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
  • 37 Answers
SOURCE: no air condition
go to honeywell.com and get tech support number
Posted on Apr 25, 2009
  • 340 Answers
SOURCE: GOODMAN CPLT36-1 WITH HONEYWELL VISION PRO STAT 8000
what is the trans former voltage needs to be 26- 28 v. and is the board fused max 3-5 amp fuse I know it is on of the two check all of your wiring. good luck Tom
Posted on Jul 12, 2009
SOURCE: Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Posted on Jan 08, 2010
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
I have a carrier 38YC(M) heat pump and trying to install a programmable t stat (honeywell RTH6350D). One of the setup steps asks what kind of pump it is: with out without backup or auxillary heating,...
"Two" of the most complicated items that "experienced" Air Conditioning ServicePeople deal with are (1) Control voltage for Heat Pumps and (2) Installing a Programable T-Stat.
My best advice to you would be to find an experienced ServicePerson to wire the T-stat for you. I can assure you that you will save time and possibly money by doing so.
Jun 12, 2011 | GE Heating & Cooling
I am trouble shooting a Bryant Hi-bred system that uses an air cooled heat pump with high efficiency gas furnace for backup and low ambient operation. How does the system decide whether to use the air...
Your t-stat should be set up so that the furnace is the second stage heat and also emergency heat. First stage (heat Pump comes on) sometimes they use Time to start 2nd stage, sometimes they use outdoor temp and this all bepends how bryant has set it up, without a model # I cannot tell you but send it and i will look in somebooks i have to tell you.
Mar 01, 2011 | Bryant Heating & Cooling
Instructions don't say where to connect the orange wire
First off ... if you have a heat pump with backup heat you cannot use this t-stat....
If you just have a heat pump and no electric or gas backup then you need to go into the advanced setup and change some of the settings to make it work for you....
This PDF has all the instructions you need...on page 11 is an 800 number to call to get honeywell professional help...
page 13 starts the adavnce control settings and page 21 tells you about the O wire hookup...
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2210EF.pdf
heatman101
Jul 27, 2010 | Honeywell Heating & Cooling
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Jan 10, 2009 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
