Question about Compaq Presario S4200NX (DF215AR#ABA) PC Desktop
My computer will run fine for 10 or 15 minutes then it will reboot itself, run fine again for 5 or 10 minutes then reboot itself again. This keeps happening over and over.
    New Friend:
Is the processor fan spinning and dose it get to full speed because it sound like its over heating and shutting down
Posted on Jan 09, 2013
2 Suggested Answers
thejus
  • 19 Answers
SOURCE: Dell Laptop Screen goes Dim After 5-10 minutes
plase use another RAM in the same machine if the sam e problem will arise..its u r mother board prblem otherwise u r ram problem
Posted on Jan 19, 2008
Bunker Hill security 8-Channel Surveillance DVR item#61229 keeps rebooting itself. "system initializing"
Rotorway Bunker Hill never lasts and it's the cheapest one with the worst resolution you just don't want to operate and put your life on the line with this unit
Jan 18, 2016 | Home Security
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
Computer comes on and is fine for a while then just cuts off,then turn it back on then its fine for a while then cuts back off.
Hello
To start with, you should check all your hardware. A loose connection somewhere or a faulty piece of hardware could be the reason, the computer keeps rebooting itself. In case your RAM stick is not fitted properly, or is corrupt, the computer displays an error message on the screen and keeps rebooting itself. The same problem occurs with a hard disk. You can use 'Memtest86' to run a hard drive check.
You may at times come across an error message on your screen, like a system failure error, before rebooting by itself. There is a particular solution to this type of problem. You should first go to the My Computer icon and right click on it. Select properties, and a window will appear on your screen. Click Advanced tab → Start Up and Recovery → Settings. After clicking the settings option, you will have to uncheck the box next to Automatically Restart. Click OK twice. This will prevent the computer from rebooting itself and you can redress the issue.
A different way to tackle the problem of 'computer keeps rebooting itself', would be to restart your computer in the Safe Mode. Allow the computer to boot fully and let your windows operating system load fully. Now, if your computer keeps rebooting itself even in the safe mode, there is a problem either with the operating system or hardware. And if your computer is not rebooting itself in safe mode, the problem is related to certain software.
Over heating is another reason why your computer keeps rebooting itself. Not many people pay attention to this aspect though. The fan responsible for keeping the CPU cool, may be malfunctioning or there could be dirt settled between the fan and CPU. Any one of these could be the reason for your problem. Either clean the fan area, or replace it if necessary. Try providing proper ventilation for your CPU, so that it stays as cool as possible.
You computer could reboot on it's own if you have installed improper drivers. Right click on the 'My Computer' icon, and click on 'Properties' from the menu list which appears. A new window will open. Select the 'Hardware' tab, and click on 'Device Manager'. A list will be displayed on the screen in which you will have to check all categories. Is you see any red or yellow warning icons, make sure you update that particular driver from the internet.
Dec 13, 2010 | Computers & Internet
Wireless connection keeps dropping
Ok, START>>RUN>>services.msc (enter) When the windows comes up, scroll down to DHCP, set to OFF & Disable. Then find, Zero Configuration, and do the same, back out, and reboot. See if this helps any.
Apr 03, 2010 | D-Link AirPlus DI-524 Wireless Router
My computer keeps rebooting and will not even let me start it up in safe mode.I blew the dust out of it and it restarted and let me into the desk top for about 5 minutes but then shut down before I had a...
Constant rebooting of a computer can be cause by alot of reason the most common for this is due to oevrheating, to check if this is a overheating problem try to open the case of the tower and put a electric fan in front of the tower to coll it down then power ON thecomputer and if it booted up fine with a electric fan blowing on the tower we're sure that you need to add some colling device on the computer tower, But if still do the same thing the problem here is the power supply unit it needs a replacement already....
Oct 22, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Computer keeps rebooting
try to check if your IDE cable is plug-in correctly. insert it correctly. try to restart your computer.
Aug 10, 2007 | IBM TravelStar 60GH 60 GB Hard Drive
Compaq Presario S4200NX (DF215AR#ABA) PC Desktop Logo
91 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
