Question about Dometic NDR 1292 Refrigerator
Circut Breaker trips
My Dometic RV unit keeps tripping the circuit breaker during operation. It works fine for a few days after I start a trip then will only work on gas. I have unplugged the ice maker but it makes no difference. A local "authorized" repair dealer checked and told me that the unit was drawing the correct amount of power. They could not observe the malfunction but it still blows in the field. Any way you can point me?
Jim
  • 481 Answers
  • i have no experience with RV units but if it were in a house i would suspect a bad breaker or a problem with the outlet itself. breakers  only trip when the wiring is gets hot.
  • unless it is a ground fault breaker (usually on the outlet) then this would trip if the flow of electricity is grounded. ground fault breakers do go bad often.
  • i think if the refrigerator itself had a problem then it would be consistent (as far as it is pulling amps anyway). not work fine sometimes and not others.
Posted on Jul 08, 2008
Refrig circuit breaker
It needs to be determined wether it's a dead short or the compressor is bad. A dead short is when the hot (colored) wire is in contact with the neutral (white) wire in a 120 V system.
I would get to the compressor connection box and disconnect the power from the compressor and turn the circuit breaker on. If it trips, it's a wiring problem. If it doesn't trip, the compressor is shorted internally.
As an alternate test to disconnect the compressor, you can turn the thermostat to off and reset the breaker, if it trips, then it's a wiring problem, if it doesn't trip and as soon as you turn the thermostat to on, then you must go to disconnecting the compressor and check it again with the compressor disconnected.
Other tests, an electrical meter is required.
Apr 12, 2014 | Dometic Refrigerators
TRAULSEN RDT232 REFIGERATOR/FREEZER. TRIPS CIRCUIT
Since you are convinced that the circuit is sufficient, look for a voltage drop during start up. In the unique case, when both units try to start at the same time, a voltage drop can cause overamping and trip the breaker.
Look at that and let me know if we need to go any farther
Jun 06, 2010 | Traulsen Commercial 2 Door Cooler /...
Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Apr 19, 2010 | Dometic RM2652 Refrigerator
Kenmore fridg pops circut breaker,
Sounds like a shorted heater. You advanced manully, unit runs till timer goes to defrost. Timer contacts switch, defrost heater shorted trips breaker.
Apr 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Mar 19, 2009 | Refrigerators
Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Dec 12, 2007 | Refrigerators
Dometic NDR 1292 Refrigerator Logo
647 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
