Picture gone black but sound still works? is there a bulb blown and can i fix it myself?
  • 597 Answers
The problem is not the lamp, if it is the lamp, then your television will not be having sound. It will not come on either, you will only be having the blinking led/power light.
The problem is the t-con board, it is located at the middle of the main board of the television, all you have to do is to unplug the television, then you leave it for about 6 hours so the high voltage will dissipate because televisions store currents in them. Then you unscrew the screws around the back of the television, then you assess the main board, the t-con board is in the middle of the main board. All you have to do is disconnect it, get a new one and fix it in, then reassemble the television back together and it will work perfectly fine.
It is an easy fix, you can ask a friend to assist you when doing this.
Take care and good luck.
Posted on Jan 01, 2011
    Problem Solver:
  • 15 Answers
Posting the make and model would be helpful.
If it's a DLP then there would be a bulb.
If it's LCD there there would be several bulbs, but most likely the inverter or power supply have gone bad.
If it's plasma It's most likely a power supply issue.
Panasonic TX-L42E5B tv sound working but screen is black
It can also be the YMain board or the back light inverter board or a capacitor or fuse has blown on the power supply board. Which you usually lose sound before you lose both sound and picture. Try to hard reset is for about 4-6 hours by completely unplugging it.
Mar 25, 2014 | Panasonic VIERA TX-L42E5B 42" LED TV...
Brake lights on Peugeot 205 gone out is it a fuse to change or more than that also rear indicator driver side light not working? What i basically want to know is it something i can fix myself?
Yes you can ..check the fuses with a test light or if you have running lights but no brake lights pull the bulb to ensure they are not blown as well the brake pedal switch may be in need of adjustment start with those areas 1st
Sep 12, 2009 | 2001 Daewoo Nubira
Sony cybershot dsc-h1 flash bulb has blown
You need to have it fixed at a service center.
Aug 13, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
My hitachi turns on and has a red/green glow, but no picture on it. It sounds like it is running, but there is no picture or sound. It recently had a power surge go through it. What could have gone wrong...
have you checked the bulb in the tv? sounds like the bulb is no good they are around 40-60 bucks...make sure tv is off and unplugged before checking and dont touch it just look to see if its blown
Jun 04, 2009 | Hitachi 60V500 60" Rear Projection...
Picture is gone
the bulb has blown.... if you get the bulb out and replace it yourself, you would still be looking at the same price range, bulbsa are expensive... i suggest let the repairguy do it but if you do try it yourself, there should be a panel at the back of the tv that opens where you can then proceed to replace the bulb
Mar 17, 2009 | RCA Televison & Video
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
