Question about Toshiba Satellite Pro L300 Notebook
Restart every 5 minutes for too much heat - Toshiba Satellite Pro L300 Notebook
  • Toshiba Master
  • 6,771 Answers
If the fan and the heat sink are clogged with dirt the cpu processor is overheating and will usually shut the laptop down. Try a can of compressed air and clean the fan "usually on the bottom" next use the can on the open vents on the back of the laptop, give it a good blast. if it works it will be a quick fix and should be a warning to have it properly cleaned and serviced by a computer professional.
Posted on Jan 01, 2011
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
My lennox heat pump frequently shows df and cold air pumps out for about 5 minutes then restarts. what is causing this?
Its getting too cold outside for the heatpump to operate. It must defrost the coil. You should have backup electric heat inside your airhandler, possibly not setup or possibly not even there. On your tstat in settings or set up look for heat pump with back up electric heat
Dec 11, 2016 | Heating & Cooling
Manual Transmission can push start...turn it off and will restart with the starter,,,after sitting more than 5 minutes will not start
sounds like a bad connection or bad starter, when it runs it will heat up starter. when its cold the metal or bad connection will expand and contract. check main all connections going to starter
Sep 20, 2015 | Hyundai Motor 1999 Tiburon
2002 Malibu stalls while driving, doesn't over heat. But can start smelling gas fumes before it stalls. usually wait about 5 mins then restarts. in higher elevation runs fine but in lower elevatio
It sounds like the catalytic converter could possibly be almost completely plugged up not allowing the exhaust to leave the engine like it should. It just builds up in the cylinder head and when it gets too much in it built up and there's no where to go, it'll stall the engine. By letting it sit for a few minutes, it gives the exhaust time to find a way out and the car will restart.
Mar 27, 2013 | Chevrolet Malibu Cars & Trucks
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
My PB-400E will shut done after about 5 minutes and can't restart for about 30 minutes, whats wrong?
It is over heating clean out all the debree that is in it take off all the plastics and clean off the motor and fins
Mar 20, 2012 | Echo Garden
Fan blower run but it will not ignite and heat unit brand is acarrier split unit
To get proper heat your setting temp +5 degree than room temp. And mode should be in " Heat".
And wait for 3 to 5 minutes. If still not stats, restart the unit and observe the following. If your unit is with RV, check click sound after 3 minutes. If not RV is not working properly. If it's with heating element, check for power in the element after 3minutes. If not check wiring.
Dec 27, 2010 | Heating & Cooling
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
Toshiba Satellite Pro L300 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
