Question about Microsoft Xbox 360 Console
My X box 360 was working correctly until recently Now when I turn it on I find that My Start uup picture is on one channel ( HDMI-1) and the sound is on another channel (HDMI-2) and I have un pliugged and replugged it in the diffrent with the correct corresponding colors but the sound still remains on another channel the picture while still on another channel is clear the sound is alos clear but is not synched as one unified system can you help witht his problem
  • Teddy Taylor Jan 01, 2011
    Tell me something if I pput in my E-mail address correctly why does your system then tell me that my e-mail address is not valid. Why is that it is very disconcerting to see that especially when the person has entered in the correct information and checked to see that it was correct and it still is but your system does not allow for a check off to say the address is correct please continue with the log on process so I can the information that i need
  • Microsoft Master
  • 4,924 Answers
If the sound is on the hdmi 2 on the tv ..plug the hdmi cable on the hdmi 2 plug ....and after that open it up ..get into settings and put the sound and image on hdmi ..
here are the instructions for auto settings ..
  • Disconnect any previous cables you were using for the PS3
  • With PS3 off connect the HDMI cable to the PS3 and the TV
  • Hold down the PS3 power button, it will beep once but keep holding down the power for another 5 seconds till you get another beep
  • If all went well the PS3 should be set to the HDMI connection
For to manually connect it ..follow this instructions ..
  • Connect both the AV cables (white/red/yellow) and HDMI cables to the TV and PS3
  • Now turn on the PS3 and go to the "Settings" and then "Display Settings" then "Video Output Settings". Select "HDMI"
  • Now we need to do the same for the audio. Go to "Settings" > "Sound Settings" > "Audio Output Settings" and change it to "HDMI"
This way you will have image on av during the set-up mode..if you want to make changes in the ps3 settings ..
Posted on Jan 02, 2011
  • Catalin Turcu
    Catalin Turcu Jan 02, 2011
    By the way ..this being a little odd ...you may try to reset the tv to the factory settings first ..
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
Xbox 360 turns on but wont work
If you are getting a black screen make sure evryting is connected properly. Make sure you are on the correct tv channel. If you are using HDMI pick that channel on your tv.
Aug 10, 2014 | Microsoft Xbox 360 Console
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
