Question about Samsung WF328AAW Front Load Washer
What does code NF mean - Samsung WF328AAW Front Load Washer
    Novelist:
  • 222 Answers
Program error we need a authorized service technician to fix it.dont try to repair the electronic program.
Posted on Jan 01, 2011
Maytag Neptune MAH6500AWW '03 front load nf code it is OVERFILLING won't shut off, water pouring out door! new drain pump last week & checked hoses in front 2 days ago. now this, help?
nf stands for no fill, so this means the washer's water level sensor is defective or plugged with dirt. That is why it is overfilling.
Nov 09, 2016 | Maytag Washing Machines
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What dose the NF means
Hi Kathy, the NF code means No Fill which indicates water is not passing to the drum, this could be the water taps are off or blocked or the door is not shut properly so stopping the water from entering! Have you just installed or was it running previously?
Oct 25, 2014 | Washing Machines
FRONT LOAD WASHER samsung model WF338AAW/xaa
you need to sort this part out level sensor located near to the door switch and main board.
samsung boardpng-vn1wiordb5lxotmqu1or3lil-1-4.png wiring will be similar to this. might have a blocked air feed from the drum don't blow into the sensor take the clear pipe off and blow down that to make sure its not blocked, washing powered and stuff can block the line.
Jan 13, 2018 | Washing Machines
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
Nf code on a wf350 samsung
nf means that your washer has tried to fill but was unsuccessful. Remedy: make sure the water faucets are open all the way, the inlet screens are clear, and there are no kinks in the hose.
Jul 06, 2012 | Washing Machines
Have a code its NF what does that mean?
NF stand for no fill, check your water supply.
Jan 26, 2011 | Maytag MAH9700AWM Neptune Front Load...
The code nf appears during the washing cylce, what does that mean?
NF is a water supply error. The waters supply valves are malfunction or there is something in the hoses blocking the water. Turn the water off and disconnect them and see if there is anything obstructing the water
Jan 06, 2011 | Washing Machines
Samsung WF328AAW Front Load Washer Logo
444 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
