Question about Bosch HGS 255 Gas Kitchen Range
Bosch Range HGS3052. When I turn a knob to turn on a burner all four ignitors click and spark. But one seems to short out, and to click farther toward its base. That burner doesn't light (without a match). It looks OK (No cracks that I can see).
mgprice
  • 744 Answers
SOURCE: gas range; ignitor will not stop clinking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Posted on Nov 29, 2009
  • 457 Answers
SOURCE: We have a Bosch range top built into our counter
there is 4 switches in there some time in sequence. it has to dried out with blow dryer or replace the switches .the front knob toeplate has to be removed also the hob has to be removed.nyc appliance repair is agreat company to handle this situation.
Posted on Feb 26, 2010
  • 5 Answers
SOURCE: I have a Bosch gas range Model: HGS346UC 0/1.
If the cooker has a digital clock it needs to be reset to manual or until 00.00 appears on display . To do this hold " - " button until the 00.00 is displayed .
Then press and hold the "+" and "-" buttons in both together at the same time until all settings have been cancelled . Try the oven now and it should come on.
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch HGS5052U Gas Kitchen Range doesn't stop
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Apr 21, 2010
heatman101
  • 43501 Answers
SOURCE: the ignitor is clicking consistantly
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Apr 17, 2011
Ignitors continue to pop altho all four knobs are in off position Kitchenaid gas stove top Model #KGCT305X Serial #XB2806974 ir X52606974
heatman101
Apr 21, 2011 | Microwave Ovens
Thermador cooktop ignitors won't stop clicking
I have the same range top. I am looking for the switch assembly. Do you know where I can buy this part? Please email me if you do. prboardman@yahoo.com
Dec 30, 2009 | Cooktops
Ignitors constantly click.
Hi, it is possible, that your spark module, need replacing, but it could be other things too. could be faulty ignitor switch, whenever you turn knob to light burner, it activate switch, remove burners, lift top off, you will see, that each knob are connected to valve with two, or some model has one wire, connected to it, check for any breaks in wiring harness, could be something simple like bruise wire touching cooker body, etc. also turn knob and light any burner, turn knob clockwise all the way, let burner light, then gently turn knob counter clockwise and listen to hear if clicking stop, if clicking continue until burner goes off, it's possible you'll need to replace spark module, sometimes, they get short circuited, takes about 30 mins to replace module, $90/ hr. oouch, big companies, does that price, includes, price of module? can you get a regular repair guy, ask a friend they might know one. good luck.
Aug 08, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Dec 10, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
All 4 ignitors just stopped working on the stove top...no more 'clicking' sounds
1 Check to be sure unit is properly connected to power supply.
2 Check for a blown circuit fuse or a tripped main circuit breaker.
3 Check to be sure ignitor is dry and clicking. Burner will not light if ignitor is damaged, soiled or wet. If ignitor doesn’t click, turn control knob OFF.
4 Burner ports may be clogged.
Dec 03, 2007 | Maytag MGR6775 Stainless Steel Kitchen...
Bosch HGS 255 Gas Kitchen Range Logo
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
