Question about RCA F36649 36" TV
Smoke coming out of tv, and bad, burning plastic smell
The picture is a bit 'stretched' out, and sometime screeen 'quivers' or 'flickers'. This has been happening for some months, but yesterday, the tv was on for several hours, and by afternoon, we smelled a horrible, plastic burning smell, and saw light smoke coming out from the top of the tv somewhere. We unplugged it, and have done nothing since.
2 Suggested Answers
SOURCE:
ekcnoel
  • 998 Answers
SOURCE: my tv technika 42 inch there smoke coming out of
Try to open the back cover of your tv but be sure to unplug it, then try to look for a bulge up capacitor beside the flyback transformer. if you see this capacitor try to replace it with the same value. feel free to send feed back good day and best regards.
Posted on Aug 02, 2011
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
I have 1993acura legend that overheats white smoke out tailpipe ....when starting warm engine put puts to an idle..sometimes dies..and no power...trani slips out of gear when coming to a stop
Jesse, I would stop driving it immediately until you figure out the problem. Does the smoke have a blue hue to it? If so you're probably burning a bit of oil which means you probably have one or more worn out engine components such as valve guides or piston rings.
If the smoke is think and white, take a good smell of it. Does it smell sweet(Relative to other car smells)? This means you're burning coolant. If this is the case, you probably have a blown cylinder head gasket or it could be as bad as a cracked cylinder or block.
Either way, continuing to drive if any of these is the problem will cause even more damage to your car. Running in these conditions will begin to foul your spark plugs which is probably why you're starting to see it dying.
Aug 18, 2013 | Vehicle Parts & Accessories
My mazda 626 has a strong potent smell coming from the exhaust
You don't mention what that smell is reminiscent of?
You don't mention the colour of the "smoke" and you didn't say whether the engine is petrol or diesel?
You don't mention whether the road behaviour/performance is normal?
White smoke is almost always steam or in the case of a diesel it could be an unburned fuel mist, grey/black is excess fuel and blue or grey/blue is burning oil.
Some steam is fairly normal until the engine and exhaust system is hot but excessive amounts could be one symptom of head gasket trouble. If the engine is drinking coolant and sending it through the exhaust as steam it will sometimes smell spicy.
Burning oil smells a bit like burned eggs in the frying pan.
If the car hasn't ultra-low sulphur oil and fuel the catalytic converter will convert sulphur traces into hydrogen sulphide - the bad egg gas...
Sep 27, 2017 | 1998 Mazda 626
Why is there smoke?
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Aug 23, 2012 | Toshiba REGZA 37RV530 LCD TV
My tv technika 42 inch there smoke coming out of the back at the top there a plastic burning smell and the picture is flickering and dull
Aug 02, 2011 | RCA F36649 36" TV
My 2002 montero was smoking really bad (white smoke) it smelled like burning plastic. I took it home and let it sit for 1/2 hour. I started it and the smoke faded away, but when i accelerate to take off it...
HAVE YOU NOTICED COOLANT LOSS,RECENTLY?KEEP THE COOLANT LEVELS FULL,CHECK TO SEE FOR ANY LOSS AT ALL! OIL SMOKE IS MORE BLUE THAN WHITE,BUT FUEL CAN HAVE A LIGHT BLUE SMOKE.Antifreez more whitesh with a similar smell of antifreeze.
Sep 12, 2010 | 2002 Mitsubishi Montero Sport
Smoking out the back and burning smell inside.
check for a cracked head that smoke you see is probably antifreeze coming out of the coolant trench in the block itself or could just be a bad gasket on your head
May 06, 2010 | 2004 Mazda 6
Burning Smell with Samsung HC-p5241w
dont fear the smoke behind. firstly open your tv. get a brush and clean the in side,it might be other particals dropped in side.
you are able to see where the smoke is coming from.
a qualified tech will solve that without wasting time on it.
Jan 07, 2009 | Goodmans 257NS 20" TV
Smell of Burning Plastic
you could have a short in the wire harness that runs up your steering column. i would check under the dash for worn,frayed or burnt wires immediately. you have a great potential for an electrical fire. good luck. please rate this solution
Aug 30, 2008 | 2004 Saturn VUE
RCA F36649 36" TV Logo
576 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
