Question about Garmin nuvi 670 GPS Receiver
I changed my battery on my garmin 670 and the small thin connection came loose . I thought I reconnected it (with much difficulty) but now my touchscreen doesn't work. i thought it slide into the connection but it wouldn't go back in so I slid it in to another place over the connection
  • ira Jan 02, 2011
    Thank you. That solves the problem. Unit is working well.
    President:
  • 670 Answers
Garmin uses a connector that has a hinged part that flips up to release the ribbon cable. You can't slide the touchscreen ribbon cable into the connector until you release the hinge. To release the hinge use something small like a needle or a round toothpick. Insert the needle where the ribbon cable should go and gently flip the hinge up. Once the hinge is flipped, you can insert the ribbon cable into the connector and then flip the hinge down to lock the cable into the connector. Reassemble the GPS. Hope this helps you.
Posted on Jan 02, 2011
  • Stephen Lam Jan 02, 2011
    Happy to be able to help you. Thanks for using Fixya!
Update garmin nuvi 670
with unit Off
Using the USB connector supplied connect the gps to computer.... the computer will see the USB Drive
Now go to MyGarmin.com register there and update and get your maps there, it will detect your model for you
Oct 20, 2010 | Garmin nuvi 670 GPS Receiver
Install replacement battery in Garmin Nüvi 660 and 670. How is cabinet opened?
The Garmin 660 and 670 like most Garmin satnavs cannnot be opened unfortunately. Garmin say that the battery may be replaced by sending the unit back to them only.
Jul 24, 2010 | Garmin Nuvi 660 GPS Receiver
I'm trying to change the battery in my Garmin 670. How do I open the case without breaking it?
Please don't try this yourself.... I receive weekly horror stories from people who now have a permanent paperweight. Please see this link:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Feb 26, 2010 | Garmin Nuvi 660 GPS Receiver
Hello, my Garmin 670 froze up on me and the touch pad does not work. I reset the unit several times without luck!! Can you help? Thank You Frank
You might just need to recalibrate the screen. Start by getting to the SETTINGS > DISPLAY page. Select RECALIBRATE and follow the directions.
Now, if the screen doesn't respond at all, you'll probably have to arrange for service. Contact Garmin Support for additional help with your nuvi 670 below:
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact
I hope this helps!
Oct 30, 2009 | Garmin nuvi 670 GPS Receiver
Garmin won't fully turn on
there is a reset button under the thin frame around your screen. remove the frame by prying it up with your fingernail, push the reset button and your problem will be fixed
Mar 21, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Battery doesen't keep the charge. I can't open the case to change battery forerunner 305
Hi Samdot,
I have just been through a similar problem through ingress of water into the device (They are not in the slightest bit water proof)
My device would power on, but only in the cradle attached to the usb and it would say the battery was fully charged after 4 seconds.
Any way, the battery can be replaced using the following method.
Take a decent, thin penknife and gently lever the top off the Garmin (follow the crease above the buttons). There are no catches to be aware of it is just lightly glued.
Once the lid is off you will be able to remove the two circuit boards (they just sit in there) and you will see the battery in the bottom of the case.
Unscrew the two small screw above the battery connections and you will be able to replace the li-ion battery which is in place.
I can provide images if that would be useful.
Phil
Jun 17, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin nuvi 670 GPS Receiver Logo
173 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
