Question about Whirlpool MH7135XE Microwave Oven
The light bulbs in the hood of my Whirlpool microwave model # MH7135XE don't work even after replacing them twice. What is the problem.
  • michael jensen Jan 02, 2011
    I don't see your post for the problem.
  • michael jensen Jan 03, 2011
    I have a Whirlpool microwave hood combo model # MH7135XE and both bulbs outside in the hood underneath don't work. I have replaced them twice so I know it can't be the bulbs. Someone said that it might be a circuit board. Any solutions?
  • 10,515 Answers
When the microwave lights don't work, the problem is either the light bulbs, or the relay on the display control board. If you've already replaced the light bulbs and that didn't fix the problem, the relay is shorted and the display control board will need to be replaced. It's very common for the relay on the control board to short out when the bulb does because the relay is very weak. The only fuses on this microwave cut out the entire display and all the lights. There is absolutely nothing between the control board relay and the lights other than wire.
You just unplug the microwave, then remove the screws going into the top plastic vent grille. Remove the vent and that will expose a screw at the top of the control panel. Remove that screw and the control panel will pull up and off. That will allow you to access and replace the control board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 04, 2011
Model MH7130xez won't heat. everything else works. the clock, timer and lights. does this model have a fuse?
if unit won't heat, then there is a problem with either the magnetron or the diode. if its the magnetron, the microwave will sound almost normal. if its the diode, it will make a humming sound
Mar 26, 2011 | Whirlpool MH7135XE Microwave Oven
Oven has no power, outlet has power
The fuse inside the m/w has blown. Remove the cabinet and replace it with the same type and amperage.
Jun 23, 2010 | Whirlpool MH7135XE Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Light does not work even after changing the bulb this is the light that shines over the stove top (Kenmore Micro model # 721.80412500
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more information or to arrange repairs.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 10, 2009 | Whirlpool MH7135XE Microwave Oven
Stuck light bulb in micro wave hood.
Be sure the oven is unplugged from the wall first.
In many cases, you have to break out the glass from the bulb and then use small needlenose pliers to unscrew the bulb base.
Once you get the lamps replaced, if they won't turn on or turn off, then you also have a damaged circuit board, which we regularly repair nationwide for $39.95 postpaid.
Details are at our site, linked is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | Whirlpool MH7135XE Microwave Oven
Whirlpool microwave @ MX6130XEQ-0
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Jan 06, 2008 | Whirlpool MH7135XE Microwave Oven
Microwave Hood Light Problem
We see this a lot. The problem is probably not the wiring, but on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Dec 31, 2007 | Whirlpool MH7135XE Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
104 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
