Question about KitchenAid KEBS177 Electric Single Oven
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
  • 1,998 Answers
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Posted on Jan 01, 2011
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
I have a Kitchenaid superba convection/gas oven model KGR1607hblg (?) I had soup overflow from the top burner and now the burners will not ignite. When turned on they will spark but nothing catches.
Make sure that all the soup was cleaned out of the little holes in the burner that the gas comes out of. You can use a toothpick or some other small object like that to try to clean them out
Mar 23, 2011 | KitchenAid Ovens
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid Superba Selectra 24
Before you decide to find out about the self cleaning feature... read this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 14, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Feb 12, 2010 | KitchenAid Ovens
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
Aug 24, 2017 | KitchenAid Ovens
KitchenAid KEBS177 Electric Single Oven Logo
98 people viewed this question
Top KitchenAid Ovens Experts
ashburton
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
