Question about Zanussi ZBF360 Electric Single Oven
How do i change the light bulb in a Zanussi oven ?
Turn off at the wall and remove the light cover inside the oven by turning anticlockwise, this may be stiff, I use a well wrung out dishcloth.
You can see the bulb, which should be screwed out of its holder with care, also care when replacing. a I screwed mine in too hard and snapped the holder, but my oven is 5 years old.
Hope that helps
Posted on Jan 12, 2011
Model 944064576. Why doesn't it heat?
check for some grounded connections. thanks .
Mar 01, 2016 | Zanussi Ovens
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
My zanussi oven blew, I changed element still not working, seems my bulb blew 2 and connection as I taken it out, would this stop the circuit from working as I have no power to cooker and switches ect are...
When the element blew , it may have taken out either the selector switch or possibly the toc, if the bulb has blown the oven should still heat up .
Mar 06, 2015 | Zanussi Ovens
What can cause the Circuit Breaker to trip out when the door of my Zanussi ZYB594X oven is opened and the internal light comes on?
I suppose, the light did not work because the circuit breaker was released.
In this case, try to find a short-circuit in the following circuit : microswitch (door lock) - power board - light bulb.
Dado
Oct 18, 2014 | Zanussi Ovens
Replace light
The instructions state:
1. Ensure the oven is disconnected from the electrical supply.
2. Turn the glass cover anticlockwise.
3. Remove the faulty bulb and replace with the new one.
4. Refit the glass cover.
5. Reconnect to the electrical supply.
Jan 09, 2014 | Zanussi ZBF360 Electric Single Oven
Zanussi oven zbf 360 + bulb blows repeatedly
bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
Mar 24, 2017 | Zanussi ZBF360 Electric Single Oven
How long should an igniter last on a gas cooker
depends if its a batteie or mains if battrie change when it stop working if its mains any time its light a light bulb and they cant be fixed you have to replace it 4-5 years some times but new cookers dont last long at all 2 years some times ok
Oct 17, 2012 | Zanussi Ovens
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
The oven light stopped working so i replaced it but it still does not work although the oven works, I have tried opening and shutting the door a few times but this does not work either
I would first of all try another bulb, if that does not work, then could be a faulty door switch, or bad contacts in bulb holder.
If you can access it, then disconnect the 2 wires going to the door switch and join them together, this will prove if the door switch is faulty, or if there is some other fault.
Dec 28, 2010 | Zanussi ZBF360 Electric Single Oven
Change oven thermostat
Not familiar with the brand - but there are two types of temperature sensors - i am assuming here that the person meant temperature sensor rather that a thermostat.
1 bulb type sensor
2 rtd type sensor (metal looking tube usually installed at back)
If its the bulb sensor - then there is a long tube from the bulb to the main dial on the front panel. All of this must be removed to change it. (power turned off) The knob on the dial removed and the front panel removed and the screws removed and the bulb threaded through - reverse to installed.
If its the rtd - then they are usually secured with two screws inside the oven (look inside to see) loosen those then pull the unit towards you the connecting wires should come through there should be a quick connector - (if under counter type) remove the old sensor and connect new one. Thread the wires back through the hole and secure the new sensor with screws - if the screws were damaged replace with only stainless screws
Aug 22, 2008 | Zanussi ZDQ895 Electric Double Oven
Zanussi ZBF360 Electric Single Oven Logo
1,825 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
