Can I down load any thing to get a better wire less connnection, it worked in the beginning but not now any more i have a "AirPort Extreame" wire less router thanks Alex keller
    Sergeant:
    Novelist:
  • 179 Answers
The first choice for AirPort Extreme base stations in this instance is to look at the firmware. Generally, using the most recent firmware version is the preference, but in some cases actually going to an older version may increase stability. Launch the AirPort Extreme Admin Utility (in Applications/Utilities); then select the appropriate Base Station in the left-hand pane. The firmware version currently installed will appear on the right-hand side.
The current version is at least 5.7. However, many folks have corrected dropout issues with their AirPort Extremes by reverting to Version 5.5.1. This link will take you to the download page for 5.5.1. Download the file, and then use the Updater application to install it. A caution in this approach is that you may lose some features that perhaps you had been using, but the rate of success for this approach is significant. You can revert back to your current version (be sure to write it down before you change it) if you wish.
NOTE that you MUST be sure that you are working with the firmware for the AirPort Extreme, and NOT the firmware for the AirPort Express. They are not the same.
Hope that's helpful.
Posted on Jan 01, 2011
Can I repair an airport express 802.11n? I bought a broken airport express on ebay ($20 incl. shipping) expecting that the power supply was the issue and knowing that I could cut the thing open and work...
I am suppose to add the solution here but unfortunately i am here to explain the problem. I got the new Airport Express. I have HP Pavillion and running with Windows Home VISTA. I tried almost here and there everything which is mentioned on forum. But it is not working.Laptop can connect with router but router is not getting connected with Internet. It's always displaying local access only which is killing me. I will try to give one more try to this setup otherwise i need to return this **** and get something else.
Sep 20, 2011 | Apple AirPort Express Base Station with...
Connected Airport Extreme wireless router unit to a PC. Airport Utility interface screen shows message: "Airport Utility unable to find Airport wireless devices...." Displays rescan button...
You may contact Windows Customer Service for any kind of help you require. You can also call on Microsoft Windows technical support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5216 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
May 18, 2017 | Apple AirPort Extreme Router
I have airport set up at home. One laptop receives a good singal another one does not.
AirPort signal strength is directly affected by things like concrete walls and metal ducting. You might want to change the physical location of the Airport to help with signal strength. Placing your Airport router in a central location based on computer usage location will help a lot.
Also changing your routers wireless channel thru Airport Utility can help. Think of it as a lot of people using the same street, it tends to get a little crowded. So changing the street means less traffic.
Dec 05, 2010 | Apple 13.3 MacBook Intel Core 2 Duo...
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the...
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Nov 14, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
I have the solid green light but neither my wife or daughter are able to get a wire-less signal on their Macbooks. A direct ethernet connnection works.
Hi gknue,
There are a couple of things that could be wrong here. It could be that the router that you are receiving your wireless signal from is having problems. If that's the case then simply turning it off for 30 - 60 secs and turning it back on may solve the problem.
If the connection is encrypted, you need to find out what the WEP or WAP key is and then connect via the settings in your Macbooks.
I'm assuming that when you say "I have the solid green light" you mean that your wireless connection is working just for you. If this is true, then look at your network settings and compare them to your wife/daughter's Macbook.
Hope I was able to help.
Sep 16, 2009 | Apple AirPort Extreme Router
Arris Modem won't work with Airport Express
Not sure how helpful this will be, as I'm running a different piece of gear, plus it requires both troubleshooting + ISP assistance.  I had a similar problem with my AirPort Extreme: AirPort Extreme saw the Arris, iBook saw the AirPort Extreme, but no internet connectivity.
  1. In my case, I needed to set the AirPort to DHCP in the AirPort Utility application.
  2. Power down the AirPort Extreme
  3. Power down the Arris. You achieve this by unplugging the Arris *and* removing the back-up battery.
  4. Wait a few moments.
  5. Insert the battery into the Arris.
  6. Plug in the Arris power supply.
  7. Wait for the Arris to go through the restart protocol; when all the lights on the front panel are solid green, the start-up is complete.
  8. Power up the AirPort Extreme; wait for the front panel light to go solid green.
As I was doing this, I had my ISP on the phone that confirmed complete connectivity of the signal path and ensured that I was online.  While the Arris was powered down, my ISP also sent a "message" to the Arris; I don't know if this was a software update or what.  I completed the AirPort set-uo through the Utility application, the AirPort restarted, and I was online.
Hope this helps.
Mar 17, 2009 | Arris Touchstone 450a (CM450) Modem
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
