Question about Microwave Ovens
Im having a heating problem with my maytag microwave, and want to check the fuse, but how do i get to it.
    Novelist:
  • 222 Answers
Not all microwave not heating is in the fuse,and remember the microwave is high voltage dont try to touch by your hand,use plier with insulation before removing the part.the fuse inside the microwave is 2 type, 1 power fuse if we have power no need to replace,the other one is HV FUSE that one is connecting in capasitor and magnetron,this like is small plastic tube with wire if you remove you can open it,check the small wire inside the glass if is broken or split its means this one is defective need to replace but if this one is ok but not heating the second problem (common) is magnetron,but much better call an service technician to check the unit if not the parts i said is defective to make sure and you get a warranty after service.
Posted on Jan 01, 2011
How do you access the fuse in a Maytag Model#MMV5000BAB
The fuse is inside. You have to remove the outer cabinet to get to it but be aware that dangerous, possibly fatal, voltages lurk inside, even with power disconnected.
Oct 23, 2016 | Maytag Microwave Ovens
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
Light and turntable work, but it won't heat
There is a fuse in this microwave.The fuse is difficult to get to.
But i do not think it is this fuse.You have lights and the carousel
spins.This sounds like the thermostat or the magnetron tube that
creates the heat.
Feb 02, 2010 | Maytag MMV5156A 1000 Watts Microwave Oven
My microwave sounds and looks like it's working but it won't heat.
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 15, 2009 | Maytag MMV5186A Microwave Oven
Maytag Microwave model MMV5165BAS. Doesn't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 10, 2009 | Microwave Ovens
Everything works on the microwave but wont heat food.
You need to remove the cover, (Power Unplugged!!) look for and check a long glass fuse (usually in a plastic housing)
It's 5000 volt and less then one amp rating.
It's a small wire inside fuse so check it with a meter.
If it's ok, it's most likely the Magnetron which is usually half the price of the machine.
If the fuse has blown, see if there is a black diode, 30-40 mm long, one end is screwed to the case.
Disconnect one end, If you have continuity both directions, it's failed causing the fuse to blow.
Replace that diode / high voltage rectifier and then the fuse.
You should be back in business.
jb
Mar 16, 2009 | Maytag MMV5156AAS Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Microwave functions but will not heat
CHECK THE HIGH VOLTAGE FUSE AND THE MAGNATRON IN THE UNIT !!!!!!!!!!!!!!! DISCHARGE THE HIGH VOLTAGE CAPACITOR OTHER WISE THE VOLTAGE STORED IN IT WILL KILL YOU!!!!!!!!!!
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Daewoo w/concave reflex system
FIRST YOU CAN CHECK THE HIGH VOLTAGE AND HIGH VOLTAGE FUSE (IF THERE) and high voltage diode, capacitor, wiring of magnetron , finally high voltage is there may be magnetron, and check the filament wiring...
Aug 22, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
