Question about Whirlpool Microwave Ovens
The light bulbs that light up underneth the microwave don't work. I've replaced the bulbs twice but they still don't work.
  • Whirlpool Master
  • 9,047 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jan 02, 2011
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
My light bulb has stopped working and will not work after I have replaced it with a new one
It could be either a separate door switch for the light that's gotten crufty (sometimes just cleaning them makes them serviceable) of the microwave that needs to be reset. Just check for tripped circuit breakers, since you've already unplugged the thing to swap the bulb (I expect.) Then check your bulb's continuity, then check the socket and switch functions if things aren't sorted.
Sep 10, 2011 | Whirlpool MH1141XM Microwave Oven
How do I replace light bulb
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Apr 08, 2011 | Daewoo Microwave Ovens
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Microwave hood combo
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would reccomend getting a new microwave and also get a small single plug surge protector for it.
Mar 21, 2008 | Microwave Ovens
Samsung Microwave problems
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 26, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
