Question about Bose & Wave& Music System
Cd won't play cd's. flashes reading disc several ties and then ejcts cd and says unreadable. these are music cd's bought from store
  • Sandra Freeman Jan 02, 2011
    Thanx. I think it was because it hadn't been used in a while. I will buy a CD cleaner.
    Sandra
    President:
  • 2,047 Answers
This problem can be caused by a couple of factors. The first of which is bad CD's if the CD's are in a bad shape they could cause this problem.
Also when the CD's are from a different region and the Bose unit happens not to support that region this could also make the CD's unreadable.
Finally if the unit has not been used in a while there is a probability that the lens has gotten dirty and would need some cleaning just run a CD cleaner on the unit.
Hope this solution has been helpful?
Posted on Jan 01, 2011
Which fuse is it to take out if the cd player reads unreadable disk for any cd I put in...2006 Hyundai sonata...
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CD player doesn read disc
2007 Sonata Ltd CD player won read discs
How to Fix Car CD Player
May 19, 2016 | Hyundai Cars & Trucks
Burned cd-r for music mp3 format. won't play in one car but played in another?
One car is rated for mp3 format while the other is not. store bought cds are not formatted mp3. From what I have read, most store bought music is in a cda format. Also read this link: http://www.cdrfaq.org/faq04.html#S4-23 It may provide you with some valuable info
May 03, 2015 | Audio Players & Recorders
DVD player will play store bought dvd's but will say unknown disc when I insert one from Netflix.
Is it possible that this is a Blu-Ray disc from Netflix? If so, It may not be able to be read on a standard DVD player.
Another possible reason for this is that the disc is somehow damaged and thus unreadable.
I'm afraid without seeing the disc I am unable to help you further.
Either way, might be time to complain to Netflix:
Netflix Customer Service(800) 279-5688(888) 638-3549(800) 585-8131
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
Bought 4gb sandisk cruzer flash drive stored music from computer but it won't play the music on the car fm transmitter
a flash drive is used mainly for storing of files, you need a device that will play the files you want, in this case a device that plays mp3s and either transfer your music to/through it.
Unless your transmitter states that it plays different media formats that is but i have never heard of that before.
hope this helps.
Dec 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Hi, don't know if I am sending this to the right bit or not. My son has an older version of the xbox and I bought him a second hand Lego Indiana Jones game which he loves, used to play ok then started...
this is in the wrong section... but... is there any visible scratches on the disc? if there is a visible scratch you can take it into a music store etc.. and they can polish out the scratch for less then $20 :) hope this is helpful
Feb 26, 2011 | Computers & Internet
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Dvd-audio cd burning issue
If you are burning a "Data Disc" (the burning software should tell you or have you select it) then music will NOT work on a CD-player. It will only work in another PC.
Data disc is for files, pictures, videos, music that you want other COMPUTERS to be able to read and play.
If you want a music CD to work in a car or something like that it NEEDS to be burned as a music disc, not data.
Hope that helps.
Mar 17, 2009 | Gateway GT5056 PC Desktop
Won't play recorded cd's
Try this link. It offers resistor changes which are designed to fix your problem of inability to play any CD R. on that model Nakamichi. jacknz0 http://home.cogeco.ca/~niteowl/Nak_MF51.jpg
Dec 31, 2007 | Nakamichi MF-51 5-Disc CD Changer
`Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Nov 19, 2007 | Sony RCD-W10 2-Disc CD Recorder
Bose & Wave& Music System Logo
787 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
