Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker isn't working. Kenmore model 106.56662500 side by side. We think it is frozen up and have been told to use a hair dryer but should we try it at the ice trays or take the back plate off and maybe a fan motor is back there that maybe is frozen up. The freezer works perfectly though.
2 Suggested Answers
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
Ice maker doesn't work
remove im and look into fill tube,if there is ice in fill tube,defrost with hair dryer and replace selinoid valve at bottom back side of unit.if not frozen replace im
Apr 09, 2013 | Kenmore Refrigerators
Kenmore Coldspot side by side ice maker not working, red lite bliking
Often I find your ice maker on the Kenmore side by side thefill tube frozen. The fill tube is ablack rubber hose located above and to the right of your ice maker. Simplypinch the tube to see if it frozen solid. If it is, use a hair dryer set onmedium to defrost the fill line. http://www.on-timeappliance.com/kenmorerefrigeratorrepairdallastx.html
Mar 24, 2012 | Kenmore Freezers
The water feed to the ice maker is frozen - I can see that it is plugged with frozen water. I was able to get the frozen water out of the chute that leads to the ice maker but I can still see the ice...
This usually means the water inlet valve that feeds the ice maker is bad. It can bypass a small amount of water and that water runs so slow that it freezes in the tube you are clearing.
The valve I am talking about is behind the frig on the bottom, it should be blue in color.
To clear the ice from the tube use hot water and a turkey baster, or a hair dryer.
The part number for the water valve is 4389177
Aug 01, 2010 | Kenmore Refrigerators
Ice maker was frozen & we used a hair dryer to defrost and now it
If there were ice cubes in the ice machine and it was doing nothing, then the ice maker is bad and you will need a replacement. This happens unfortunately. It is nothing that you did with the hair dryer tho. If I have misunderstood the problem I will gladly help further pending more information :) gl!
May 27, 2010 | Whirlpool GS6NBEXR Side by Side...
My ice maker isnt making ice. i think i need a new filter. could that cause this.
Hello, my Kenmore was also not making ice about 2 years ago, but everything else worked. It seemed that the tube directly inside the freezer where it was filling the ice trays was frozen. My husband used a hair dryer to unthaw the tube. It's been working every since. Also, my sister had a Kenmore Elite, with the same problem but her husband didn't know what the cause. So they also tried the hair dryer, and now it works fine.
Thanks
May 19, 2010 | Kenmore Refrigerators
whats the freezer temperature? it has to be at last 17.5 degrees for the ice maker to work properly.
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge ice maker
I used a hair dryer for about 5 minutes. It took a while to verify because a tray of ice had to fill and freeze before I knew my problem was fixed. No repairman!!!
Aug 18, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Kenmore Refrigerator model 363.9565512
Hello, Check the water fill tube to see if it may be frozen. It's a tube about 3/8" wide that hangs over the tray. Squeeze the tube and if it is hard, it"s frozen, if it is soft, you have another problem. If it's hard, take a hair dryer and thaw out the tube and you ice maker should be fixed.
I hope this helps.
CYA, Gator241
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
