Question about Rancilio Audrey
We've had the Rancilio Audrey now for a year and still not have had a perfect cappucino. 1. Milk. We use 3.5 dairy milk, cold before going under spout. 2. What is the middle (steam) button used for? Is it to be used in conjunction with the pressure steam release knob ? - what configuration? Lastly, any advice on how full should the ground coffee be in the twist-on metal sieve? Any help will be gratefully accepted. $700. is a lot of money for the not so perfect kitchen gadget. Last question - do you have a Rancillio service store/agent in downtown Montreal? We are a city of coffee drinkers... Louis.
  • 352 Answers
  1. That is the right milk. Use a thermometer with the milk.
  2. The middle button is used for steam. It engages the high themostat for steam.
    1. Slightly open the steam valve
    2. Turn on the middle button
    3. Keep the end of the steam wand slightly above the milk surface (0.5 mm) so the steam incorporates air into the milk. (Takes practice)
    4. Open the steam valve as the boiler heats up. (Takes practice)
    5. When the milk get to 74 C (165 F) immerse the steam wand into the milk and heat to 82 C (185 F)
    6. Turn off the middle button and shut the valve.
  3. For 90 ml of coffee, use 14 gram of ground coffee. The coffee scoop that came with the machine holds 7 grams of ground coffee as it comes out of a grinder (not packed). Tamp the coffee after it is in the sieve.
Posted on Jun 08, 2014
5 Suggested Answers
  • 10865 Answers
SOURCE: I have misplaced my Manual for the Rancilio Miss
http://www.1st-line.com/machines/home_mod/rancilio/silvia.htm
go to this link and you will have more info than u can imagine. good luck earl.
Posted on Mar 20, 2009
z34aga
  • 137 Answers
SOURCE: leaking steam valve rancilio miss audrey
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Posted on Apr 02, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Posted on Jan 21, 2010
  • 1089 Answers
SOURCE: where is the reset button on the rancilio audrey?
Once you get the top off, there are 2 thermostats on the top of the boiler. Your looking for the thermostat that is on the front of the boiler with the red button . Push the red button. If that didn't work check the ohms reading on the element. It should read 12 - 16 ohms. If it doesn't replace the element. Also did you try to turn on the steam button? Sometimes the thermostat with the red dot on it goes bad. If it will steam just replace the brew thermostat.
Posted on Feb 09, 2010
Do women who drink 3 or more glasses of cow's milk have an increased risk of hip fracture?
according to researchers in sweden and the british medical journal, yes, because of the milk sugar. low fat or skim reduces that. but what they fail to mention in many articles is that you need vitamin d to break the calcium down and help, absorb it into your body, thus helping bone structure. without d, the calcium just stores there and causes acidosis. best way to get vitamin d? sunlight. drink milk and go outside for an hour
Jan 28, 2015 | Cooking
Do you have any recipe for milk free ice cream? For lactose intollerant diet?? Perhaps Almond Milk or Soy Milk.
Here are some of the useful steps to make a milk free ice cream.
1.) Microwave the chocolate and butter-substitute for thirty seconds in a microwave-safe bowl.
2.) Add a dash of salt, and a splash of vanilla extract to taste.
3.) Put a scoop of marshmallow fluff into the bowl and stir it in thoroughly.
4.) Remove the spoon, lick it clean, and wait up to 5 minutes for your mixture to become room temperature.
5.) Place it in the freezer for 50 minutes, remove, and if it is still not frozen well, then stir it thoroughly and place it back in the freezer for another 20 minutes.
Jun 26, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
Jan 18, 2014 | Rancilio Audrey
Can anyone suggest any non dairy hot chocolate recipes for me?
You can basically substitute any non dairy products for milk and then follow the regular recipe for hot chocolate i.e. heat the 'milk' and add chocolate till it melts and stir in sugar to taste.
Be careful with the sugar amounts as some of the non dairy milks ie soya are quite sweet already.
You can try using almond or rice milk as well or just buy a non-dairy creamer.
Feb 25, 2013 | Wine & Spirits
I am beginning a diet next week and Id like to know which dairy products I can eat as part of my healthy diet and which ones I should avoid. What do you recommend?
healthy dairy products that can be incorporated in your diet include:
Low fat (1%) or skim milk
Low fat cottage cheese
Non-fat or low fat yogurt
Low-fat cheese
The following products you should avoid completely during your diet:
Ice cream
Whole milk (3.5%) and reduced fat milk (2%).
Full-fat soy milk
Yogurt with added sugars
Cream
Frozen yogurt
Feb 04, 2013 | Cooking
The milk frother has stopped rotating.....the milk heats but the frother doesnt rotate hence no froth.... am in india,mmbai so dont know where i can fix it !
The solution to rotation issues with the frother have been soved finally by myself after reading all the suggestion. The fix is simple... Your attachments have been magnitised and need to be demagnetized. It works a beauty. Run a magnet around the metal rings. Hint. Never leave them on the the frother when not being used.
Jul 09, 2011 | Nespresso Aeroccino Automatic Milk Frother
Seaco Odea Go
You can not adjust the amount of this.
/Mirran
Aug 17, 2008 | Saeco Odea Go
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
208 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
