Question about Cuisinart DLC-5 Food Processor
How do I attach the shredding disc to the detachable stem on my cuisinart pro classic food processsor?
SOURCE: food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Posted on Oct 08, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
  • 2976 Answers
SOURCE: How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Posted on Jan 05, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: I have a very old cuisinart food processor
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
Posted on Jan 17, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: need manual for food processor
The manual is available for free at Cuisinart's website
www.cuisinart.com
-Tha Mp3 Doctor
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Aug 24, 2008 | Cuisinart DLC-10S Pro Classic Food...
I can't get the blades on the processor. there is a holder that somehow snaps into the blades before they are put on the processor
The regular chopping blade requires a stem adapter. The other blades require the detachable stem. I would double-check the user manaul to get a visual on it. Cuisinart food processors are great, but they are also the hardest to assemble.
-Tha Mp3 Doctor
Jul 19, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Apr 08, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Install Cuisinart stem cover
I was able to replace my pieces thru Small appliance.com I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Oct 17, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-5 Food Processor Logo
69 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
