Question about Honeywell Heating & Cooling
The room temperature on the unit is constantly on 40 degrees and stopping the heating from kicking in
  • val_potts Jan 02, 2011
    it is a digital thermostat
  • Honeywell Master
  • 43,501 Answers
Many digital thermostats can be reset by removing all power and the batteries for at least a half an hour....this should earse and remove anything that may be programmed ino the -stat...
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Jan 02, 2011
  • 297 Answers
Do you have a digital thermostat or a manual dial thermostat?
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Ice machine , fan kicks on and off constantly
Hello Harold;
My name is Peter. I am a retired field service refrigeration technician.
Your fan is not designed to run constantly. Your fan will turn on when the set temperature falls 10-20 degrees below set temperature, and will run until the unit is 10-20 degrees above set temperature.
1.) Clean your condenser coil. This coil removes the unit heat.
2.) Check your condenser fan to make sure it is running.
3.) Check the door gaskets. They may be crushed or worn, allowing warm air to enter your unit.
Dec 23, 2014 | Refrigerators
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
I have a Haier air/heating unit. The heat has stopped working.
Keep heating mode and temp setting at minimum 3 to 4 degree C* between room and required temp.
If still not working, replace the heating sensor.
Tnx
Nov 13, 2013 | Honeywell ER150B Air Conditioner
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
I have Model: DM30A which constantly freezes up even though it is on a three foot high table and the temperature never goes below 60 degrees
The unit freezing up doesn't surprise me at all. If the temp in your room is 60 degrees then the temperature of the air will be around 40 degrees and the coil is about 20 degrees. Your expecting to much, the tempature is to cold to work properly.
Jul 08, 2011 | Haier Dehumidifiers
Ist ik for capacitors to be expose on heat inside my room when i am out because all the windows are close? the heat is about 40 to 45 degrees celcious.
Most capacitors are designed to have an effective heat usage range before they start to change capacitance values. They will normally run in an environment of below 32F to 120F without any variation in the capacitence rating of the capacitor. Beyond these points the capacity may start changing.
Apr 13, 2009 | Car Audio & Video
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Heating & Cooling Logo
103 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
