Question about Pentair Minimax NT Heater
My Pentair Mini Max NT won't come on. The control panel LED flashes between the bars (like when it is trying to read the temp) and 88.8 with the service light coming on when the 88.8 is showing and going off when the bars are showing. All of the lights on the right side light up at once when the 88.8 is showing too but go off when just the bars are showing. This cycles continuously whenever the heater is turned on.
  • 310 Answers
Check out this forum for complete answers to this problem.
http://innovationlab.pentairpool.com/forum/topics/err-display-on-minimax-nttsi
Posted on Jan 07, 2011
Testimonial: "Thank you very much. This may be exactly what has happened. I recently had the Thermistor replaced. "
Why is there no display on my pentair mini max nt?
is ther power going to it if so check power supply or main power conversion board
Aug 22, 2014 | Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
DDTC reads off at all times even when pool is circulating. It usually reads the pool temperature. Also, i don't have a green pressure LED. Can't start the gas heater either.
If you have a control system (i.e...aqualink) controls on the heater should be set to remote. If that is the case and it still gives no temp reading, it is the thermistor (temp sensor). it is very common for rats to chew through the wire.
Oct 13, 2011 | Pentair Minimax NT Heater
I have an mini max nt w 6800 controls ignitor
The voltage to this ignitor should only be 120 volts. If you are getting 240 volts to the ignitor, there is something really wrong with the wiring to the heater or in the heater.
Jul 27, 2011 | Pentair Minimax NT Heater
Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Mar 29, 2010 | Pentair Minimax NT Heater
I get one flash which is an air flow fault on my mini max nt. . . I have reset but still does not work.
check for spider webs if nothind bypass the flow switch just to check do not leave that way if heater work the flow swithc may be bad
Aug 19, 2009 | Pentair Minimax NT Heater
Mini Max Digital Control FLO error message
The pressure switch is on the inlet/outlet manifold. It has purple wires running to it. Try taking a wire and unplugging the pressure switch and jumping the 2 wires together.
May 30, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
809 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
