Question about Bosch Washing Machines
Hi, Bosch WAS28720FF/01 Washing machine sometimes empties and sometimes does not. "Pump blocked" is the typical error message. Pump and drain tube have been inspected and cleared, and there is no sign of a blockage: When the machine stops in its cycle, giving the "pump blocked" message, the issue can sometimes be resolved by switching the machine off and leaving it for an hour or two and then launching it with, say, the rinse cycle. On one occasion, error message "F37" came up. Any suggestions about what could be causing this, and what to check or replace please ? dvelup@aliceadsl.fr
  • Bosch Master
  • 744 Answers
Bosch WAS28720FF/01 Washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
  • 6 Answers
SOURCE: aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Posted on Jan 14, 2008
  • 351 Answers
if is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
Posted on Mar 26, 2008
  • 1462 Answers
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Posted on Jun 29, 2008
SOURCE: Bosch WFR 2460 washing machine
I have the same problem, I even replaced the pump and still getting the same message, so it is not a problem with pump, it is may be the control pannel, a sensor is not sending the message to the pump.
Posted on Aug 21, 2008
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
Bosch washer sometimes don't rinse
Have you cleaned out the filter in the bottom and made sure the pump is not blocked?
Apr 22, 2014 | Bosch Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Oct 20, 2012 | Bosch Washing Machines
Bosch washer Axxis+ gives following error message: "Pump blocked?" After manually draining the water it will work properly for half a dozen washloads, then the error message shows up again.
Have you tried cleaning the filter next to the drainage pipe? (Lower left near Door).
The compartment is opened by turning it anti-clockwise and pulling it out (Be wary of water coming out!).
Most likely a small obstruction (Coin, Rocks, Toothpick... and in past experiences a "thong") might be blocking your impeller.
Hope this helps, if it doesn't let me know and I'd get technical ;-)
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 03, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
I have a Bosch Exxcel showing error code F104. What does this mean
This code typically means that the pump is blocked. You should get a reputable engineer to come out and unblock it.
Feb 28, 2011 | Bosch Washing Machines
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Not spinning
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Pump blocked message
next time u clean the filter when it is empty of water. put your finger in the whole and u will find somthing wound round the impeler of the pump remove what ever is obstructing and u will have no more problems make sure u unplug the machine b4 you start doing this good luck
Sep 03, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
